Discuss
Slow pre-heat cycle
 in
When you select the "Bake" mode on the Amana Easy Touch Control 500, Model # AER5515QAW, which element(s) are activated
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Slow pre-heat cycle
  #1 (permalink)
Old 10-05-2012, 12:22 PM
Junior Member
garyld is on a distinguished road
Default Slow pre-heat cycle
Model Number: AER5515QAW   Brand: Amana   Age: 5 - 10 years
When you select the "Bake" mode on the Amana Easy Touch Control 500, Model # AER5515QAW, which element(s) are activated during the pre-heat cycle? Also, once the desired baking temperature is reached, which element(s) are activated to maintain that temperature during the remainder of the "Bake" mode?
Thank you.
Ads By Google
Related Models
Amana AER5515QAW Range - S/c F/s Ele
Amana AER5515QCW Range - S/c F/s Ele
Amana AER5515RCW Range - S/c F/s Ele
Amana AER5710BAH Range - S/c F/s Ele
Amana AER5712AAQ Range - S/c F/s Ele
Amana AER5712AAS Range - S/c F/s Ele
Amana AER5712AAW Range - S/c F/s Ele
Amana AER5712AAZ Range - S/c F/s Ele
Amana AER5712ACW Range - S/c F/s Ele
Amana AER5712ACZ Range - S/c F/s Ele
Amana AER5712BAB Range - S/c F/s Ele
Amana AER5712BAW Range - S/c F/s Ele
Amana AER5712BAZ Range - S/c F/s Ele
Amana AER5715QAQ Range - S/c F/s Ele
Amana AER5715QAS Range - S/c F/s Ele
Amana AER5715QAW Range - S/c F/s Ele
Amana AER5715QCB Range - S/c F/s Ele
Amana AER5715QCS Range - S/c F/s Ele
Amana AER5715QCW Range - S/c F/s Ele
Amana AER5715RCB Range - S/c F/s Ele
Amana AER5715RCS Range - S/c F/s Ele
Amana AER5715RCW Range - S/c F/s Ele
Amana AER5722BAB Range - S/c F/s Ele
Amana AER5722BAQ Range - S/c F/s Ele
Amana AER5722BAS Range - S/c F/s Ele
Amana AER5722BAW Range - S/c F/s Ele
Amana AER5722CAS Range - S/c F/s Ele
Amana AER5725QAB Range - S/c F/s Ele
Amana AER5725QAF Range - S/c F/s Ele
Amana AER5725QAN Range - S/c F/s Ele
Amana AER5725QAQ Range - S/c F/s Ele
Amana AER5725QAS Range - S/c F/s Ele
Amana AER5725QAW Range - S/c F/s Ele
Amana AER5735QAB Range - S/c F/s Ele
Amana AER5735QAF Range - S/c F/s Ele
Amana AER5735QAN Range - S/c F/s Ele
Amana AER5735QAQ Range - S/c F/s Ele
Amana AER5735QAS Range - S/c F/s Ele
Amana AER5735QAW Range - S/c F/s Ele
Amana AER5815RCB Range - S/c F/s Ele
Amana AER5815RCS Range - S/c F/s Ele
Amana AER5815RCW Range - S/c F/s Ele
Amana AER5845QAB Range - F/s Std Ele
Amana AER5845QAF Range - F/s Std Ele
Amana AER5845QAN Range - F/s Std Ele
Amana AER5845QAS Range - F/s Std Ele
Amana AER5845RAB Range - S/c F/s Ele
Amana AER5845RAS Range - S/c F/s Ele
Amana AER5845RAW Range - S/c F/s Ele
Amana AES1350BAW Range - S/c S/i Ele
General Electric AES15DAV1 Room air conditioner
General Electric AES18DAM1 Room air conditioner
General Electric AES23DAR1 Room air conditioner
Amana AES3540BAW Range - S/c S/i Gas
Amana AES3760BAB Range - S/c S/i Ele
Amana AES3760BAQ Range - S/c S/i Ele
Amana AES3760BAS Range - S/c S/i Ele
Amana AES3760BAW Range - S/c S/i Ele
Amana AES3760BCB Range - F/s Std Ele
Amana AES3760BCS Range - F/s Std Ele
Amana AES3760BCW Range - F/s Std Ele
Amana AES5730BAB Range - S/c S/i Ele
Amana AES5730BAF Range - S/c S/i Ele
Amana AES5730BAN Range - S/c S/i Ele
Amana AES5730BAS Range - S/c S/i Ele
Amana AET-480 Range - S/c S/i Ddraft Gas
Amana AET-480A Range - S/c S/i Ddraft Gas
Amana AET-480B Range - S/c S/i Ddraft Gas
Amana AET-480C Range - S/c S/i Ddraft Gas
General Electric AET05LHW1 Room air conditioner
General Electric AET05LJG1 Room air conditioner
General Electric AET05LJS1 Room air conditioner
General Electric AET05LJW1 Room air conditioner
Amana AEU-516 Range - S/c S/i Ddraft Gas
Amana AEU-516A Range - S/c S/i Ddraft Gas
Amana AEU-516C Range - S/c S/i Ddraft Gas
Amana AEU-516D Range - S/c S/i Ddraft Gas
Amana AEU-516E Range - S/c S/i Ddraft Gas
Amana AEU-516F Range - S/c S/i Ddraft Gas
Amana AEU-516G Range - S/c S/i Ddraft Gas
General Electric AEV24DJH1 Room air conditioner
General Electric AEV24DKH1 Room air conditioner
General Electric AEW05LJG1 Room air conditioner
General Electric AEW05LJS1 Room air conditioner
General Electric AEW05LJW1 Room air conditioner
General Electric AEW06LJG1 Room air conditioner
General Electric AEW06LJS1 Room air conditioner
General Electric AEW08AJS1 Room air conditioner
General Electric AEW10AJG1 Room air conditioner
General Electric AEW10AJS1 Room air conditioner
General Electric AEW24DHH1 Room air conditioner
General Electric AEW24DJH1 Room air conditioner
General Electric AEW24DKH1 Room air conditioner
Amana AEW3530DDB Walloven - S/c Ele
Amana AEW3530DDS Walloven - S/c Ele
Amana AEW3530DDW Walloven - S/c Ele
Amana AEW3630DDB Walloven - S/c Dbl Oven Ele
Amana AEW3630DDS Walloven - S/c Dbl Oven Ele
Amana AEW3630DDW Walloven - S/c Dbl Oven Ele
Amana AEW4530DDB Walloven - S/c Ele
Amana AEW4530DDQ Walloven - S/c Ele
Amana AEW4530DDS Walloven - S/c Ele
Amana AEW4530DDW Walloven - S/c Ele
Amana AEW4630DDB Walloven - S/c Dbl Oven Ele
Amana AEW4630DDQ Walloven - S/c Dbl Oven Ele
Amana AEW4630DDS Walloven - S/c Dbl Oven Ele
Amana AEW4630DDW Walloven - S/c Dbl Oven Ele
General Electric AEX08FAM1 Room air conditioner
Jenn-Air AEX918 Misc / Accessory
Thermador AF-7M
General Electric AF108FMP1 Room air conditioner
General Electric AF112DMW1 Room air conditioner
Admiral AF122 Freezer - Vertical
General Electric AF615DPE1 Room air conditioner
General Electric AF615DSE1 Room air conditioner
General Electric AF615DTE1 Room air conditioner
General Electric AF715DME1 Room air conditioner
General Electric AF812DMW1 Room air conditioner
General Electric AF812DNW1 Room air conditioner
General Electric AF908FMP3 Room air conditioner
  #2 (permalink)
Old 10-05-2012, 02:43 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
According the manual both elements are engaged during the preheat and bake, controlled by the board.
Here are the breakdown diagram and Replacement parts for Amana AER5515QAW RANGE- S/C F/S ELE | AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spin cycle is slow rem870 Washer Repair 2 02-20-2012 02:14 PM
very slow to complete cycle mikehep Washer Repair 1 12-29-2011 06:36 PM
Slow To Heat postman56 Oven Repair (including Ranges and Cooktops) 0 08-30-2011 07:21 PM
Spin cycle too slow jamesfjamesf Washer Repair 3 03-23-2011 02:54 AM
Spin cycle slow Ozz Washer Repair 2 01-01-2010 01:36 PM
