Discuss
Electric oven will not heat
 in
I have been trying to fix my oven as it will not heat - the range, lights and convection fan work
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric oven will not heat
  #1 (permalink)
Old 09-23-2009, 09:27 PM
tom9328 tom9328 is offline
Junior Member
tom9328 is on a distinguished road
Default Electric oven will not heat
Model Number: KERC506HWH0   Brand: Kitchen Aid   Age: 5 - 10 years
I have been trying to fix my oven as it will not heat - the range, lights and convection fan work fine.
I used my multi meter to check the elements and thermostat and everything appears fine. I thought there might be funny with the control board since there were no obvious problems anywhere else, so I replaced it. Didn't fix it.
I then replaced the thermostat as many others have suggested that part replacement and I thought the ohm reading was odd. Didn't fix it.
I do have a problem with the lock trying to lock but not working properly. I don't know if that is the reason for the problem but it too has normal readings.
Anyone have an idea if there is a thermo fuse that I can't seem to locate?
Related Models
Whirlpool KERC506HWH0
Whirlpool KERC506HWH1
Whirlpool KERC506HWH2
Whirlpool KERC506HWH3 30" Electric Range Ceran Cooktop Convection Oven
Whirlpool KERC507EAL1
Whirlpool KERC507EAL2
Whirlpool KERC507EAL3
Whirlpool KERC507EAL4
Whirlpool KERC507EAL5
Whirlpool KERC507EBL1
Whirlpool KERC507EBL2
Whirlpool KERC507EBL3
Whirlpool KERC507EBL4
Whirlpool KERC507EBL5
Whirlpool KERC507EWH1
Whirlpool KERC507EWH2
Whirlpool KERC507EWH3
Whirlpool KERC507EWH4
Whirlpool KERC507EWH5
Whirlpool KERC507HAL0
Whirlpool KERC507HAL1
Whirlpool KERC507HAL2
Whirlpool KERC507HAL3
Whirlpool KERC507HBL0
Whirlpool KERC507HBL1
Whirlpool KERC507HBL2
Whirlpool KERC507HBL3
Whirlpool KERC507HBL4
Whirlpool KERC507HBS0
Whirlpool KERC507HBS1
Whirlpool KERC507HBS2
Whirlpool KERC507HBS3
Whirlpool KERC507HBS4
Whirlpool KERC507HBT0
Whirlpool KERC507HBT1
Whirlpool KERC507HBT2
Whirlpool KERC507HBT3
Whirlpool KERC507HBT4
Whirlpool KERC507HWH0
Whirlpool KERC507HWH1
Whirlpool KERC507HWH2
Whirlpool KERC507HWH3
Whirlpool KERC507HWH4
Whirlpool KERC507YAL0
Whirlpool KERC507YAL1
Whirlpool KERC507YAL2
Whirlpool KERC507YAL3
Whirlpool KERC507YAL4
Whirlpool KERC507YAL5
Whirlpool KERC507YWH0
Whirlpool KERC507YWH1
Whirlpool KERC507YWH2
Whirlpool KERC507YWH3
Whirlpool KERC507YWH4
Whirlpool KERC507YWH5
Whirlpool KERC508LSS0 30" Electronic Range Freestanding Designer Style
Whirlpool KERC600EAL0
Whirlpool KERC600EAL1
Whirlpool KERC600EAL2
Whirlpool KERC600EAL5
Whirlpool KERC600EWH0
Whirlpool KERC600EWH1
Whirlpool KERC600EWH2
Whirlpool KERC600EWH5
Whirlpool KERC600GAL0
Whirlpool KERC600GAL1
Whirlpool KERC600GBS0
Whirlpool KERC600GBS1
Whirlpool KERC600GWH0
Whirlpool KERC600GWH1
Whirlpool KERC600HBS0
Whirlpool KERC600HBT0
Whirlpool KERC600HWH0
Whirlpool KERC601HBL4
Whirlpool KERC601HBL6
Whirlpool KERC601HBL8
Whirlpool KERC601HBT0
Whirlpool KERC601HBT1
Whirlpool KERC601HBT3
Whirlpool KERC601HBT4
Whirlpool KERC601HBT5
Whirlpool KERC601HBT6
Whirlpool KERC601HBT8
Whirlpool KERC601HWH0
Whirlpool KERC601HWH1
Whirlpool KERC601HWH3
Whirlpool KERC601HWH4
Whirlpool KERC601HWH5
Whirlpool KERC601HWH6
Whirlpool KERC601HWH8
Whirlpool KERC607EAL0
Whirlpool KERC607EAL1
Whirlpool KERC607EAL2
Whirlpool KERC607EAL4
Whirlpool KERC607EAL5
Whirlpool KERC607EWH0
Whirlpool KERC607EWH1
Whirlpool KERC607EWH2
Whirlpool KERC607EWH4
Whirlpool KERC607EWH5
Whirlpool KERC607GAL0
Whirlpool KERC607GAL1
Whirlpool KERC607GBL0
Whirlpool KERC607GBL1
Whirlpool KERC607GBS0
Whirlpool KERC607GBS1
Whirlpool KERC607GBT0
Whirlpool KERC607GBT1
Whirlpool KERC607GWH0
Whirlpool KERC607GWH1
Whirlpool KERC607HBL0
Whirlpool KERC607HBL1
Whirlpool KERC607HBL10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HBL3
Whirlpool KERC607HBL4
Whirlpool KERC607HBL5
Whirlpool KERC607HBL6
Whirlpool KERC607HBL8
Whirlpool KERC607HBS0
Whirlpool KERC607HBS1
  #2 (permalink)
Old 09-24-2009, 04:52 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for WHIRLPOOL KERC506HWH0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%209753984.pdf
Wiring diagram does show a 20 amp fuse (lower right hand corner of wiring diagram)
For the life of me I could not find it in the parts breakdowns.
Hopefully someone else will jump in with hands on experience on this model
__________________
  #3 (permalink)
Old 09-24-2009, 09:57 AM
Junior Member
Default
Thanks for your help denman. I've turned that oven upside down trying to find an amp fuse - no luck.
  #4 (permalink)
Old 09-24-2009, 02:40 PM
Senior Expert
APP Volunteer
Default
Here is a post I found, it is for a KERC500 but does show the fuse.
Kitchenaid Selectra Oven
__________________
  #5 (permalink)
Old 09-24-2009, 08:18 PM
Junior Member
Default Found the bugger
So not exactly the same as the Selectra but you sure got me looking around for any fuse hiding place.
The elusive fuse is a part of a red wire and covered in a black plastic wrap. The wire runs from the terminal to the control board. I cut out the fuse and attached the wire to the terminal and voila - heat and stink from an oven that hasn't worked in a month. Looks like the new wire is going to cost almost $100 bucks! Do you think I could get a fuse holder and new fuse and jimmy-rig it?
Just for fun, I started the clean cycle and after 1/2 an hour it errored out. Again new board, and new thermostat, so does that mean I won't be able to use the clean cycle even with a new fuse?
  #6 (permalink)
Old 09-24-2009, 08:54 PM
Senior Expert
APP Volunteer
Default
Glad you found it!!!
Can not see any reason why not as long as you use a good quality fuse holder, mount it properly and make sure it has good connection to the wires.
Fuse is probably a 20 amp slow blow.
Could be, what was the error?
__________________
  #7 (permalink)
Old 09-24-2009, 09:17 PM
Junior Member
Default
E2 F3 - overheater! & of course it locked up on me, but since I've become so intimate with this little peach I popped it right back open - but it would'nt start up again until it cooled down a bit. ugh
  #8 (permalink)
Old 09-25-2009, 07:57 AM
Senior Expert
APP Volunteer
Default
Since you have already replaced both the control board and the thermal sensor, the only thing I can think of is the wiring between the sensor and the board. I would check to see that the connectors are clean and properly crimped.
You may want to pick up a oven thermometer and check what the actual oven temp is during bake as to compared to what the unit is telling you. Do not expect it to be right on the money. If the thermometer is a lot lower then the unit is reading the sensor incorrectly. Most units allow you to calibrate the temperature plus/minus 35 degrees, perhaps this will solve the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
After Electric Cleaning Oven Will Not Heat arlenel24 Oven Repair (including Ranges and Cooktops) 1 08-04-2009 06:08 PM
Frigidaire Electric Oven Doesn't Heat sharzaz Oven Repair (including Ranges and Cooktops) 11 06-27-2009 07:38 PM
too long for electric oven to heat up... suzysrn Oven Repair (including Ranges and Cooktops) 2 06-03-2009 02:16 PM
Electric Stove - No Oven Heat tater215 Oven Repair (including Ranges and Cooktops) 3 02-20-2009 03:27 PM
Electric Oven Broiler No Heat APSMARK Oven Repair (including Ranges and Cooktops) 0 11-08-2007 07:19 PM
