Discuss
Drop in stove with grill
 in
My old oven stopped working the light will not even come on when I turn it on the top or
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Drop in stove with grill
  #1 (permalink)
Old 10-02-2012, 05:36 PM
Junior Member
309brasstown is on a distinguished road
Question Drop in stove with grill
Brand: Jenn-Air   Age: More than 10 years
My old oven stopped working the light will not even come on when I turn it on the top or bottom elements will not turn on?
Ads By Google
  #2 (permalink)
Old 10-02-2012, 05:41 PM
Junior Member
Default
I have no idea what that means I'm a woman with a broken stove can you explain.
  #3 (permalink)
Old 10-03-2012, 01:41 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Model Number Locator
Since the elements and the light all went out at the same time it sounds like a power problem.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
grill element CarolynNash Oven Repair (including Ranges and Cooktops) 0 06-24-2011 11:03 AM
Ice won't drop jimoconnor76 Refrigerator & Freezer Repair 0 05-20-2010 10:01 AM
Drop in stove clock timer replacement RichSer Oven Repair (including Ranges and Cooktops) 0 04-05-2010 06:16 PM
Frigidaire Stove Top with grill and downward vent. tori_guyton Oven Repair (including Ranges and Cooktops) 0 10-22-2009 08:25 PM
Thermador Gas Grill s11845 Microwave Repair 1 03-09-2009 07:25 PM
