Oven will not heat
I am looking for a wiring diagram, or an answer as to why my oven will not heat. I have
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat
  #1 (permalink)
Old 10-01-2012, 12:01 PM
Junior Member
mwatkins is on a distinguished road
Default Oven will not heat
Model Number: 79097453800   Brand: Kenmore   Age: 1 - 5 years
I am looking for a wiring diagram, or an answer as to why my oven will not heat. I have checked the continuity on the heat sensor, broiler and bake elements. Voltage at the out let is good. all the burners work. timer and clock work. I cant find a schematic of the oven electronic control board to check that. Any suggestions?
Related Models
Kenmore 79097453800 ELECTRIC RANGE
Kenmore 79097453801 ELECTRIC RANGE
Kenmore 79097453802 ELECTRIC RANGE
Kenmore 79097453803 ELECTRIC RANGE
Kenmore 79097453804 ELECTRIC RANGE
Kenmore 79097454800 ELECTRIC RANGE
Kenmore 79097454801 ELECTRIC RANGE
Kenmore 79097454802 ELECTRIC RANGE
Kenmore 79097459800 ELECTRIC RANGE
Kenmore 79097459801 ELECTRIC RANGE
Kenmore 79097459802 ELECTRIC RANGE
Kenmore 79097462800 ELECTRIC RANGE
Kenmore 79097462801 ELECTRIC RANGE
Kenmore 79097462802 ELECTRIC RANGE
Kenmore 79097463800 ELECTRIC RANGE
Kenmore 79097463801 ELECTRIC RANGE
Kenmore 79097463802 ELECTRIC RANGE
Kenmore 79097469800 ELECTRIC RANGE
Kenmore 79097469801 ELECTRIC RANGE
Kenmore 79097469802 ELECTRIC RANGE
Kenmore 79097471790 ELECTRIC RANGE
Kenmore 79097472800 ELECTRIC RANGE
Kenmore 79097472801 ELECTRIC RANGE
Kenmore 79097472802 ELECTRIC RANGE
Kenmore 79097472803 ELECTRIC RANGE
Kenmore 79097473800 ELECTRIC RANGE
Kenmore 79097473801 ELECTRIC RANGE
Kenmore 79097473802 ELECTRIC RANGE
Kenmore 79097473803 ELECTRIC RANGE
Kenmore 79097473804 ELECTRIC RANGE
Kenmore 79097473805 ELECTRIC RANGE
Kenmore 79097475790 ELECTRIC RANGE
Kenmore 79097476790 ELECTRIC RANGE
Kenmore 79097478790 ELECTRIC RANGE
Kenmore 79097479800 ELECTRIC RANGE
Kenmore 79097479801 ELECTRIC RANGE
Kenmore 79097479802 ELECTRIC RANGE
Kenmore 79097479803 ELECTRIC RANGE
Kenmore 79097483800 ELECTRIC RANGE
Kenmore 79097502000 ELECTRIC RANGE
Kenmore 79097503000 ELECTRIC RANGE
Kenmore 79097509000 ELECTRIC RANGE
Kenmore 79097512100 ELECTRIC RANGE
Kenmore 79097513100 ELECTRIC RANGE
Kenmore 79097519100 ELECTRIC RANGE
Kenmore 79098022800 ELECTRIC RANGE
Kenmore 79098022801 ELECTRIC RANGE
Kenmore 79098022802 ELECTRIC RANGE
Kenmore 79098023800 ELECTRIC RANGE
Kenmore 79098023801 ELECTRIC RANGE
Kenmore 79098023802 ELECTRIC RANGE
Kenmore 79098029800 ELECTRIC RANGE
Kenmore 79098029801 ELECTRIC RANGE
Kenmore 79098029802 ELECTRIC RANGE
Kenmore 79098032800 ELECTRIC RANGE
Kenmore 79098033800 ELECTRIC RANGE
Kenmore 79098039800 ELECTRIC RANGE
Kenmore 79098042900 ELECTRIC RANGE
Kenmore 79098042901 ELECTRIC RANGE
Kenmore 79098043900 ELECTRIC RANGE
Kenmore 79098043901 ELECTRIC RANGE
Kenmore 79098049900 ELECTRIC RANGE
Kenmore 79098049901 ELECTRIC RANGE
Kenmore 79098052000 ELECTRIC RANGE
Kenmore 79098053000 ELECTRIC RANGE
Kenmore 79098053001 SEARS/ELECTRIC RANGE
Kenmore 79098059000 ELECTRIC RANGE
Kenmore 79099012100 ELECTRIC RANGE
Kenmore 79099012101 SEARS/ELECTRIC RANGE
Kenmore 79099012102 ELECTRIC RANGE
Kenmore 79099013100 ELECTRIC RANGE
Kenmore 79099013101 ELECTRIC RANGE
Kenmore 79099013102 SEARS/ELECTRIC RANGE
Kenmore 79099014100 ELECTRIC RANGE
Kenmore 79099014101 SEARS/ELECTRIC RANGE
Kenmore 79099014102 ELECTRIC RANGE
Kenmore 79099019100 ELECTRIC RANGE
Kenmore 79099019101 SEARS/ELECTRIC RANGE
Kenmore 79099019102 ELECTRIC RANGE
Kenmore 79099112300 ELECTRIC RANGE
Kenmore 79099112301 ELECTRIC RANGE
Kenmore 79099112302 ELECTRIC RANGE
Kenmore 79099113300 ELECTRIC RANGE
Kenmore 79099113301 ELECTRIC RANGE
Kenmore 79099113302 ELECTRIC RANGE
Kenmore 79099114300 ELECTRIC RANGE
Kenmore 79099114301 ELECTRIC RANGE
Kenmore 79099114302 ELECTRIC RANGE
Kenmore 79099119300 ELECTRIC RANGE
Kenmore 79099119301 ELECTRIC RANGE
Kenmore 79099119302 ELECTRIC RANGE
Kenmore 79099122400 ELECTRIC RANGE
Kenmore 79099122401 ELECTRIC RANGE
Kenmore 79099122403 ELECTRIC RANGE
Kenmore 79099122404 ELECTRIC RANGE
Kenmore 79099122405 ELECTRIC RANGE
Kenmore 79099122407 ELECTRIC RANGE
Kenmore 79099122408 ELECTRIC RANGE
Kenmore 79099122409 ELECTRIC RANGE
Kenmore 7909912240A ELECTRIC RANGE
Kenmore 7909912240B ELECTRIC RANGE
Kenmore 79099123400 ELECTRIC RANGE
Kenmore 79099123402 ELECTRIC RANGE
Kenmore 79099123403 ELECTRIC RANGE
Kenmore 79099123404 ELECTRIC RANGE
Kenmore 79099123405 ELECTRIC RANGE
Kenmore 79099123407 ELECTRIC RANGE
Kenmore 79099123408 ELECTRIC RANGE
Kenmore 79099123409 ELECTRIC RANGE
Kenmore 7909912340A ELECTRIC RANGE
Kenmore 7909912340B ELECTRIC RANGE
Kenmore 7909912340C ELECTRIC RANGE
Kenmore 79099124400 ELECTRIC RANGE
Kenmore 79099124401 ELECTRIC RANGE
Kenmore 79099124403 ELECTRIC RANGE
Kenmore 79099124404 ELECTRIC RANGE
Kenmore 79099124405 ELECTRIC RANGE
Kenmore 79099124407 ELECTRIC RANGE
Kenmore 79099124408 ELECTRIC RANGE
Kenmore 79099124409 ELECTRIC RANGE
  #2 (permalink)
Old 10-02-2012, 01:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
I also could not find a wiring diagram for this unit.
If you are looking for an actual schematic for the board , you are out of luck as none of the manufacturers publish this info.
Does the unit show the oven as ready or does it stay in preheat.
If it shows ready check the oven sensor.
Here is a link about it, look at 7, 8, 20 and 21.
If it stays in preheat then unplug the unit and check the wiring from the unit's terminal strip to the control board and also from/to the oven elements. If all OK then odds are that the control board is shot.
Some units have a safety thermostat in the line going to the elements but looking at a parts breakdown for this unit it does not appear to have one.
You will probably also need a keyboard overlay as they often get ruined trying to remove them.
Control AP4365963
Overlay AP4356463
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Oven won't heat up to pre-heat setting tmilam Oven Repair (including Ranges and Cooktops) 0 04-24-2011 04:48 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Main oven does not heat but the stove top and the bottom oven work wes2ii Oven Repair (including Ranges and Cooktops) 5 09-23-2010 01:22 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
