Discuss
Dead control panel on Bosch Range
 in
The oven control panel (smooth glass panel) will not respond to user input. Pressing the pad to use oven, set
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dead control panel on Bosch Range
  #1 (permalink)
Old 09-30-2012, 06:38 PM
Junior Member
rcavalie is on a distinguished road
Default Dead control panel on Bosch Range
Model Number: HGS3052UC   Brand: Bosch   Age: 5 - 10 years
The oven control panel (smooth glass panel) will not respond to user input. Pressing the pad to use oven, set time, etc. yields no response. It started to get hard to input selections (required many tries to enter input) about 6 months ago. It got progressively worse and now doesn't work at all. Gas range works, panel lights work but can't set time since input pad doesn't work. Control knob seems to work. Range burner igniter works.
Would like to troubleshoot this problem but don't know how. I'm relatively handy and do almost all my own repairs. I'm afraid it needs a new display panel which may cost more than the unit is worth. Can someone please help me determine if it can be cost effectively fixed or if I should scrap it and look for another unit?
Thanks.
Related Models
Thermador HGSI42TS
Thermador HGSW36TS
Maytag HJ61201JRT ELECTRIC WATER HEATER
Maytag HJ61202JRT ELECTRIC WATER HEATER
Maytag HJ6301JLS ELECTRIC WATER HEATER
Maytag HJ6301JLSCSA ELECTRIC WATER HEATER
Maytag HJ6301JRT2 ELECTRIC WATER HEATER
Maytag HJ6301JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6302JLS ELECTRIC WATER HEATER
Maytag HJ6302JLSCSA ELECTRIC WATER HEATER
Maytag HJ6302JRT2 ELECTRIC WATER HEATER
Maytag HJ6302JRT2CSA ELECTRIC WATER HEATER
Maytag HJ630NORT GAS WATER HEATER
Maytag HJ630NORT2 GAS WATER HEATER
Maytag HJ630NORT2CGA GAS WATER HEATER
Maytag HJ630NORTCGA GAS WATER HEATER
Maytag HJ630PORT GAS WATER HEATER
Maytag HJ630PORT2 GAS WATER HEATER
Maytag HJ630PORT2CGA GAS WATER HEATER
Maytag HJ630PORTCGA GAS WATER HEATER
Maytag HJ6401JLS ELECTRIC WATER HEATER
Maytag HJ6401JLSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRS ELECTRIC WATER HEATER
Maytag HJ6401JRSCSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2 ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6401JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6401JRT2F ELECTRIC WATER HEATER
Maytag HJ6401JT4W ELECTRIC WATER HEATER
Maytag HJ6401JT4WCSA GAS WATER HEATER
Maytag HJ6402JLS ELECTRIC WATER HEATER
Maytag HJ6402JLSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRS ELECTRIC WATER HEATER
Maytag HJ6402JRSCSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2 ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSA ELECTRIC WATER HEATER
Maytag HJ6402JRT2CSAF ELECTRIC WATER HEATER
Maytag HJ6402JRT2F ELECTRIC WATER HEATER
Maytag HJ6402JT4W ELECTRIC WATER HEATER
Maytag HJ6402JT4WCSA GAS WATER HEATER
Maytag HJ640NBDS GAS WATER HEATER
Maytag HJ640NBDSCGA GAS WATER HEATER
Maytag HJ640NBDVT GAS WATER HEATER
Maytag HJ640NBDVTCGA GAS WATER HEATER
Maytag HJ640NBPDT GAS WATER HEATER
Maytag HJ640NBPDTCGA GAS WATER HEATER
Maytag HJ640NBRS GAS WATER HEATER
Maytag HJ640NBRSCGA GAS WATER HEATER
Maytag HJ640NBRT GAS WATER HEATER
Maytag HJ640NBRT2 GAS WATER HEATER
Maytag HJ640NBRT2CGA GAS WATER HEATER
Maytag HJ640NBRTCGA GAS WATER HEATER
Maytag HJ640NBRTF GAS WATER HEATER
Maytag HJ640NBRTFCGA GAS WATER HEATER
Maytag HJ640NOCT42W GAS WATER HEATER
Maytag HJ640NOCT52W GAS WATER HEATER
Maytag HJ640NOLS GAS WATER HEATER
Maytag HJ640NOLSCGA GAS WATER HEATER
Maytag HJ640NORS GAS WATER HEATER
Maytag HJ640NORS2 GAS WATER HEATER
Maytag HJ640NORS2CGA GAS WATER HEATER
Maytag HJ640NORSCGA GAS WATER HEATER
Maytag HJ640NORT GAS WATER HEATER
Maytag HJ640NORT2 GAS WATER HEATER
Maytag HJ640NORT2CGA GAS WATER HEATER
Maytag HJ640NORTCGA GAS WATER HEATER
Maytag HJ640NOVET GAS WATER HEATER
Maytag HJ640NOVET2 GAS WATER HEATER
Maytag HJ640NOVET2CGA GAS WATER HEATER
Maytag HJ640NOVETCGA GAS WATER HEATER
Maytag HJ640NOVIT GAS WATER HEATER
Maytag HJ640NOVIT2 GAS WATER HEATER
Maytag HJ640PBDS GAS WATER HEATER
Maytag HJ640PBDSCGA GAS WATER HEATER
Maytag HJ640PBDVT GAS WATER HEATER
Maytag HJ640PBDVTCGA GAS WATER HEATER
Maytag HJ640PBPDT GAS WATER HEATER
Maytag HJ640PBPDTCGA GAS WATER HEATER
Maytag HJ640PBRS GAS WATER HEATER
Maytag HJ640PBRSCGA GAS WATER HEATER
Maytag HJ640PBRT GAS WATER HEATER
Maytag HJ640PBRT2 GAS WATER HEATER
Maytag HJ640PBRT2CGA GAS WATER HEATER
Maytag HJ640PBRTCGA GAS WATER HEATER
Maytag HJ640PBRTF GAS WATER HEATER
Maytag HJ640PBRTFCGA GAS WATER HEATER
Maytag HJ640POCT42W GAS WATER HEATER
Maytag HJ640POCT52W GAS WATER HEATER
Maytag HJ640POLS GAS WATER HEATER
Maytag HJ640POLSCGA GAS WATER HEATER
Maytag HJ640PORS GAS WATER HEATER
Maytag HJ640PORS2 GAS WATER HEATER
Maytag HJ640PORS2CGA GAS WATER HEATER
Maytag HJ640PORSCGA GAS WATER HEATER
Maytag HJ640PORT GAS WATER HEATER
Maytag HJ640PORT2 GAS WATER HEATER
Maytag HJ640PORT2CGA GAS WATER HEATER
Maytag HJ640PORTCGA GAS WATER HEATER
Maytag HJ640POVET GAS WATER HEATER
Maytag HJ640POVET2 GAS WATER HEATER
Maytag HJ640POVET2CGA GAS WATER HEATER
Maytag HJ640POVETCGA GAS WATER HEATER
Maytag HJ640POVIT GAS WATER HEATER
Maytag HJ640POVIT2 GAS WATER HEATER
Maytag HJ6501JLSW ELECTRIC WATER HEATER
Maytag HJ6501JLSWCSA ELECTRIC WATER HEATER
Maytag HJ6502JLSW ELECTRIC WATER HEATER
Maytag HJ6502JLSWCSA ELECTRIC WATER HEATER
Maytag HJ650NBDS GAS WATER HEATER
Maytag HJ650NBDSCGA GAS WATER HEATER
Maytag HJ650NBDVT GAS WATER HEATER
Maytag HJ650NBDVTCGA GAS WATER HEATER
Maytag HJ650NBPDT GAS WATER HEATER
Maytag HJ650NBPDTCGA GAS WATER HEATER
Maytag HJ650NBRT GAS WATER HEATER
Maytag HJ650NBRT2 GAS WATER HEATER
Maytag HJ650NBRT2CGA GAS WATER HEATER
Maytag HJ650NBRTCGA GAS WATER HEATER
Maytag HJ650NKRT GAS WATER HEATER
Maytag HJ650NKRTCGA GAS WATER HEATER
  #2 (permalink)
Old 04-14-2013, 09:15 PM
Junior Member
brad65 is on a distinguished road
Default Bosh range control panel quit working
If you have a Bosh gas or electric range with a touch pad above the burners and it stops working.....first thing, remove the top rear sheet metal plate at the back (2 screws) and look and see if the circuit board has come away from the front panel...Bosh uses 2 sided tape to secure the display panel and it can become loose and your oven and clock won't work....
All ya have to do is press it back into place and maybe add some duct tape to the outer flanges to hold it better.....
Good luck..
  #3 (permalink)
Old 02-02-2014, 01:19 PM
Junior Member
philroe is on a distinguished road
Smile Permanent fix
Tape is not the best solution. You need some way to keep the control board permanently in contact with the glass. I roughly carved a soft piece of wood so that it would wedge firmly between the control board and the back side of the housing. Solved it completely
  #4 (permalink)
Old 03-23-2014, 12:38 PM
Junior Member
jjanse is on a distinguished road
Default Wood worked
A piece of wood between the circuit board and back cover solved the problem for me to. Tried duct tape first but that didn't last but 10 minutes. Thanks for the tip.
  #5 (permalink)
Old 09-29-2014, 07:43 PM
Junior Member
PaulPit is on a distinguished road
Default
Thank you for the really helpful suggestion. Really helped.
  #6 (permalink)
Old 05-19-2017, 10:44 AM
gms gms is offline
Junior Member
gms is on a distinguished road
Default
+1
Was ready to spend $200+ on a new control board but found this thread. Just as predicted, the tape on one side of the mounting bracket had slid down, disabling the light/time/off buttons. I used some big tooth picks to support the bracket & no more problems.
  #7 (permalink)
Old 11-11-2017, 04:03 PM
Junior Member
roksto is on a distinguished road
Default
thanks for this thread- I called Bosch when I thought the control panel was bad and they told me the part was $140.00 plus $125.00 labor just to determine what was wrong! Bosch should be ashamed of themselves. The adhesive is obviously a bad idea in this location where the heat can affect the control panel from moving away from the glass. i also took a wood skewer, broke it into pieces and wedged the pieces so the control panel was closer to the glass! And if it happens again, i know exactly the problem and what to do! Thanks Again!
  #8 (permalink)
Old 02-28-2018, 02:59 PM
Junior Member
Charitym is on a distinguished road
Default Bosch range dead control panel
What if the control panel is front-mounted instead of above the burners?
  #9 (permalink)
Old 03-09-2018, 12:50 PM
Junior Member
unie01 is on a distinguished road
Default
sub'd to this thread
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Range Control Panel Dead Bruce7799 Oven Repair (including Ranges and Cooktops) 1 12-16-2011 03:16 AM
Control Panel dead Pauly H Dryer Repair 0 06-11-2011 12:01 PM
Kitchenaid Gas Range Control Panel DEAD adl Oven Repair (including Ranges and Cooktops) 0 04-12-2011 08:01 PM
GE Gas Range Control Panel Is Dead bfm Oven Repair (including Ranges and Cooktops) 0 05-29-2010 10:26 AM
Control Panel is dead rileyd Oven Repair (including Ranges and Cooktops) 3 10-13-2009 05:10 PM
