| » Burner or control? Super capacity 365 electric |
Model Number: RF378PXGZ0 Brand: Whirlpool Age: 5 - 10 years
Left front heating element does not turn on. Turning on the control knob lights the power light next to the control knob but the element does not warm and the hot surface light on the cooktop does not come on. Should I suspect the control, the element, or something else entirely? BTW. All other elements are working fine.
Thank you Will Ads By Google Related Models |
Replacement parts for Whirlpool RF378PXGZ0 30" ELECTRIC RANGE | AppliancePartsPros.com
Should I suspect the control, the element, or something else entirely? Probably either the element or the control although there is always an outside possibility of a bad connection/wire. Remove the element and check it with a meter. If it checks OK replace the control. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| Whirlpool Super Capacity 465 burner orifices | benkku | Oven Repair (including Ranges and Cooktops) | 0 | 11-16-2011 11:17 AM |
| whirlpool super capacity | jmiday | Oven Repair (including Ranges and Cooktops) | 0 | 07-11-2011 11:04 AM |
| whirlpool super capacity 465 electric oven doesn't always stay at temp | proyfz450 | Oven Repair (including Ranges and Cooktops) | 0 | 01-04-2011 03:21 PM |
| GE Super Capacity Electric Dryer Start Switch problem | dmkamper | Dryer Repair | 1 | 12-08-2010 05:14 PM |
| whirlpool super capacity 465 | boomer1011 | Oven Repair (including Ranges and Cooktops) | 2 | 11-13-2008 04:17 PM |
