Discuss
GE fault code f3
 in
When bake is turned on the unit comes on for half a minute and goes off after that. After four
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE fault code f3
  #1 (permalink)
Old 09-26-2012, 09:43 PM
Junior Member
ricky1842 is on a distinguished road
Default GE fault code f3
Model Number: jgs968s0h3ss   Brand: GE   Age: 1 - 5 years
When bake is turned on the unit comes on for half a minute and goes off after that. After four minutes the f3 code appears.
Ads By Google
Related Models
General Electric JGS968SEK1SS Gas range
General Electric JGS968SEK2SS Gas range
General Electric JGS968SEK3SS Gas range
General Electric JGS968SH1SS Gas range
General Electric JGS968SH2SS Gas range
General Electric JGS968SH3SS Gas range
General Electric JGS968SH4SS Gas range
General Electric JGS968SH5SS Gas range
General Electric JGS968SH6SS Gas range
General Electric JGS968TEK1WW Gas range
General Electric JGS968TEK2WW Gas range
General Electric JGS968TEK3WW Gas range
General Electric JGS968TH1WW Gas range
General Electric JGS968TH2WW Gas range
General Electric JGS968TH3WW Gas range
General Electric JGS968TH4WW Gas range
General Electric JGS968TH5WW Gas range
General Electric JGS968TH6WW Gas range
Jenn-Air JGS9900BDB Range - S/c S/i Ddraft Gas
Jenn-Air JGS9900BDF Range - S/c S/i Ddraft Gas
Jenn-Air JGS9900BDS Frigidaire/freezer
General Electric JGSC07GEJ1 Electric range
General Electric JGSC07GEJ2 Gas range
General Electric JGSC08GEK1 Electric range
General Electric JGSC08GEK3 Electric range
General Electric JGSC12GEP1 Gas range
General Electric JGSC12GER1BG Gas range
General Electric JGSC12GET1BG Gas range
General Electric JGSC12GEV1BG Gas range
General Electric JGSP10GEK1 Electric range
General Electric JGSP10GEK2 Gas range
General Electric JGSP10GEK3 Electric range
General Electric JGSP20GEP1 Electric range
General Electric JGSP20GEP2 Gas range
General Electric JGSP20GER1BG Gas range
General Electric JGSP20GER2BG Gas range
General Electric JGSP20GER3BG Gas range
General Electric JGSP20GET1BB Gas range
General Electric JGSP21GEP1 Gas range
General Electric JGSP21GEP2 Gas range
General Electric JGSP21GER1WH Gas range
General Electric JGSP21GER2WH Gas range
General Electric JGSP21GER3WH Gas range
General Electric JGSP21WET1WW Gas range
General Electric JGSP22GEV1BB Gas range
General Electric JGSP22GEV3BB Gas range
General Electric JGSP23BEW1BB Gas range
General Electric JGSP23BEY1BB Gas range
General Electric JGSP23BEY2BB Gas range
General Electric JGSP23BEY3BB Gas range
General Electric JGSP23BEY4BB Gas range
General Electric JGSP23BEY5BB Gas range
General Electric JGSP23CEY1CC Gas range
General Electric JGSP23WEV1WW Gas range
General Electric JGSP23WEV2WW Gas range
General Electric JGSP23WEV5WW Gas range
General Electric JGSP23WEV6WW Gas range
General Electric JGSP23WEW1WW Gas range
General Electric JGSP23WEY1WW Gas range
General Electric JGSP23WEY2WW Gas range
General Electric JGSP23WEY3WW Gas range
General Electric JGSP23WEY5WW Gas range
General Electric JGSP23WEY6WW Gas range
General Electric JGSP23WEY7WW Gas range
General Electric JGSP28BEK1BB Gas range
General Electric JGSP28BEK2BB Gas range
General Electric JGSP28BEK3BB Gas range
General Electric JGSP28BEK4BB Gas range
General Electric JGSP28CEK1CC Gas range
General Electric JGSP28CEK2CC Gas range
General Electric JGSP28CEK3CC Gas range
General Electric JGSP28CEK4CC Gas range
General Electric JGSP28SEK1SS Gas range
General Electric JGSP28SEK2SS Gas range
General Electric JGSP28SEK3SS Gas range
General Electric JGSP28SEK4SS Gas range
General Electric JGSP28WEK1WW Gas range
General Electric JGSP28WEK2WW Gas range
General Electric JGSP28WEK3WW Gas range
General Electric JGSP28WEK4WW Gas range
General Electric JGSP30GEP1 Electric range
General Electric JGSP30GEP4BG Gas range
General Electric JGSP30GEP5BG Electric range
General Electric JGSP30GER1BG Gas range
General Electric JGSP30GER2BG Gas range
General Electric JGSP30GER3BG Gas range
General Electric JGSP30GET1BB Gas range
General Electric JGSP31GEP1 Gas range
General Electric JGSP31GEP4 Gas range
General Electric JGSP31GEP5WG Gas range
General Electric JGSP31GEP6WG Electric range
General Electric JGSP31GER1WG Gas range
General Electric JGSP31GER2WG Gas range
General Electric JGSP31GER3WG Gas range
General Electric JGSP31WET1WW Gas range
General Electric JGSP32GEV1BB Gas range
General Electric JGSP32GEV2BB Gas range
General Electric JGSP32GEV3BB Gas range
General Electric JGSP33WEV1WW Gas range
General Electric JGSP33WEV2WW Gas range
General Electric JGSP33WEV3WW Gas range
General Electric JGSP33WEV4WW Gas range
General Electric JGSP33WEV5WW Gas range
General Electric JGSP33WEV6WW Gas range
General Electric JGSP33WEV7WW Gas range
General Electric JGSP40AES1AG Gas range
General Electric JGSP40AES2AG Gas range
General Electric JGSP40AET1AA Gas range
General Electric JGSP44AEV1AA Gas range
General Electric JGSP44AEV2AA Gas range
General Electric JGSP44AEV3AA Gas range
General Electric JGSP44AEY1AA Gas range
General Electric JGSP44BEY1BB Gas range
General Electric JGSP44BEY2BB Gas range
General Electric JGSP44BEY3BB Gas range
General Electric JGSP44CEY1CC Gas range
General Electric JGSP44WEY1WW Gas range
General Electric JGSP44WEY2WW Gas range
General Electric JGSP44WEY3WW Gas range
General Electric JGSP44WEY4WW Gas range
  #2 (permalink)
Old 09-27-2012, 03:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "F3" error code means that the control board senses the oven temperature sensor open.
Remove the oven sensor harness from the control board and measure the sensor resistance. It suppose to be about 1100 ohms at the room temperature.
If the reading is incorrect, replace the oven sensor.
If the reading is correct, replace the oven control board.
- The oven sensor Part number: WB21T10007
- The oven control board Part number: WB27T11252
Here are the breakdown diagrams and Replacement parts for General Electric JGS968SH3SS Gas range | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fault code F2:65 schism427 Oven Repair (including Ranges and Cooktops) 0 01-15-2011 02:38 PM
fault code F2:E3 artsee Oven Repair (including Ranges and Cooktops) 0 01-06-2011 08:20 AM
f50 fault code Mrhaneync Washer Repair 1 06-17-2010 09:00 PM
Fault code F05 Janine Washer Repair 3 05-04-2010 05:14 PM
Lg ref fault code mwill5 Refrigerator & Freezer Repair 0 01-02-2009 09:58 AM
