Discuss
Magic Chef F7 code-how to fix?
 in
I have an electric Magic Chef oven s/n 25C023608893, model 38HA-3TXW that beeps continuously and displays the code F7 in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic Chef F7 code-how to fix?
  #1 (permalink)
Old 09-26-2012, 05:01 PM
Junior Member
RonFromNM is on a distinguished road
Default Magic Chef F7 code-how to fix?
Model Number: 38HA-3TXW   Brand: Magic Chef   Age: More than 10 years
I have an electric Magic Chef oven s/n 25C023608893, model 38HA-3TXW that beeps continuously and displays the code F7 in the clock area after pressing any control button. Unplugging it clears the code, but pressing any control button brings the error code and beeping back after about 10 seconds (for example, pressing broil and setting on low starts working normally, but then the error code. Any control key will end up like this). Any recommendations on how to clear this permanently or what part needs replacement? Thank you!
Ads By Google
Related Models
Magic Chef 38HA-3TXW-ON Range - S/c F/s Ele
Magic Chef 38HA-42TXW Range - S/c F/s Ele
Magic Chef 38HA-4TXW Range - S/c F/s Ele
Magic Chef 38HA-5TVW Range - S/c F/s Ele
Magic Chef 38HA-6TVW Range - S/c F/s Ele
Magic Chef 38HA-6TVW-EV Range - S/c F/s Ele
Magic Chef 38HB-2CX-ON Range - S/c F/s Ele
Magic Chef 38HB-3TX-ON Range - S/c F/s Ele
Magic Chef 38HG-2CX-ON Range - S/c F/s Ele
Magic Chef 38HK-26CX-ON Range - S/c F/s Ele
Magic Chef 38HK-2CX-ON Range - S/c F/s Ele
Magic Chef 38HK-3TXW-ON Range - S/c F/s Ele
Magic Chef 38HK-42TXW Range - S/c F/s Ele
Magic Chef 38HK-4TXW Range - S/c F/s Ele
Magic Chef 38HK-5TXW Range - S/c F/s Ele
Magic Chef 38HK-6TXW Range - S/c F/s Ele
Magic Chef 38HN-26CX-ON Range - S/c F/s Ele
Magic Chef 38HN-2C Range - S/c F/s Ele
Magic Chef 38HN-2CW Range - S/c F/s Ele
Magic Chef 38HN-2CX-ON Range - S/c F/s Ele
Magic Chef 38HN-2CXW-ON Range - S/c F/s Ele
Magic Chef 38HN-36TX-ON Range - S/c F/s Ele
Magic Chef 38HN-3TW Range - S/c F/s Ele
Magic Chef 38HN-3TX-ON Range - S/c F/s Ele
Magic Chef 38HN-3TXW-ON Range - S/c F/s Ele
Magic Chef 38HN-42TVW-EV Range - S/c F/s Ele
Magic Chef 38HN-42TXW Range - S/c F/s Ele
Magic Chef 38HN-4TXW Range - S/c F/s Ele
Magic Chef 38HN-5TVW Range - S/c F/s Ele
Magic Chef 38HN-5TVW-EV Range - S/c F/s Ele
Magic Chef 38HN-6TVW Range - S/c F/s Ele
Magic Chef 38HN-6TVW-EV Range - S/c F/s Ele
Magic Chef 38HN-6TVW-SC Range - S/c F/s Ele
Magic Chef 38HY-2C Range - S/c F/s Ele
Magic Chef 38HY-2CX-ON Range - S/c F/s Ele
Magic Chef 38HY-2CXW-ON Range - S/c F/s Ele
Magic Chef 38HY-3TX-ON Range - S/c F/s Ele
Magic Chef 38HY-3TXW-ON
Magic Chef 38JA-2CW Range - S/c F/s Ele
Magic Chef 38JA-2CX-94 Range - S/c F/s Ele
Magic Chef 38JA-2CX-ON Range - S/c F/s Ele
Magic Chef 38JA-2CXW-ON Range - S/c F/s Ele
Magic Chef 38JA-6AVW Range - S/c F/s Ele
Magic Chef 38JK-6AXW Range - S/c F/s Ele
Magic Chef 38JN-2CW Range - S/c F/s Ele
Magic Chef 38JN-2CX-94 Range - S/c F/s Ele
Magic Chef 38JN-2CX-ON Range - S/c F/s Ele
Magic Chef 38JN-2CXW-ON Range - S/c F/s Ele
Magic Chef 38JN-6AVW Range - S/c F/s Ele
Magic Chef 38JN-6AVW-EV Range - S/c F/s Ele
Magic Chef 38JN-6AVW-SC Range - S/c F/s Ele
Magic Chef 3962VVA Walloven - S/c Dbl Oven Ele
Magic Chef 3962VVV Walloven - S/c Dbl Oven Ele
Magic Chef 3962XVB Walloven - S/c Dbl Oven Ele
Magic Chef 3968VVA Range - S/c F/s T/svr/booster El
Magic Chef 3968VVV Range - S/c F/s T/svr/booster El
Magic Chef 3968XVB Walloven - S/c Dbl Oven Ele
Whirlpool 3C
Whirlpool 3CA2000XMW0
Whirlpool 3CA2100XMW0
Whirlpool 3CA2100XMW1
Whirlpool 3CA2781XSW0
Whirlpool 3CA2781XSW1
Whirlpool 3CAP2762BN0
Whirlpool 3CAP2762BW0
Whirlpool 3CAP2782BN0
Whirlpool 3CAP2782BW0
Whirlpool 3CDA1100W1
Whirlpool 3CDA1100W2
Whirlpool 3CDA1100W5
Whirlpool 3CDA2000F1
Whirlpool 3CDA2000G0
Whirlpool 3CDA2000W0
Whirlpool 3CDE1700W0
Whirlpool 3CE2110XMW0
Whirlpool 3CE2110XMW1
Whirlpool 3CE2110XMW2
Whirlpool 3CE2910XSN0
Whirlpool 3CE2910XSN1
Whirlpool 3CE2910XSW0
Whirlpool 3CE2910XSW1
Whirlpool 3CEP2910BW0
Whirlpool 3CEP2910DW0
Whirlpool 3CEP2920DW0
Whirlpool 3CEP2950DN0
Whirlpool 3CEP2950DW0
Whirlpool 3CEP2960DN0
Whirlpool 3CEP2960DN2
Whirlpool 3CEP2960DW0
Whirlpool 3CEP2960DW2
Whirlpool 3CFA2000W1
Whirlpool 3CFA2000W3
Whirlpool 3CFA2000W4
Whirlpool 3CFA2000W5
Whirlpool 3CFA2000W6
Whirlpool 3CFCH4AE93
Whirlpool 3CFCH4AS93
Whirlpool 3CFCH4WE93
Whirlpool 3CFCH4WS93
Whirlpool 3CFCHWE93
Whirlpool 3CFCS3AE92
Whirlpool 3CFCS3AS92
Whirlpool 3CFCS3WE92
Whirlpool 3CFCS3WS92
Whirlpool 3CFE2500W0
Whirlpool 3CFE2500W2
Whirlpool 3CFE2510W1
Whirlpool 3CFE2510W2
Whirlpool 3CG2901XSN0
Whirlpool 3CG2901XSN1
Whirlpool 3CG2901XSN3
Whirlpool 3CG2901XSW0
Whirlpool 3CG2901XSW1
Whirlpool 3CG2901XSW3
Whirlpool 3CGP2901DN0
Whirlpool 3CGP2901DW0
Whirlpool 3CGP2901DW1
Whirlpool 3CGP2951BN0
Whirlpool 3CGP2951BW0
Whirlpool 3CGP2951DN0
  #2 (permalink)
Old 09-27-2012, 11:21 AM
Junior Member
Default
Appear to have fixed it. Unplugged oven and took apart the clock/control board off its holder (be careful of the plastic tabs that hold it in place) and to pull off the knob from the shaft for adjusting values. (Be sure to touch the oven metal first to dissipate any static charge you have on yourself so you don't zap the board... assuming it isn't zapped already) Used CRC electronic cleaner on the plastic slides and around the pushbuttons on the front panel working them in and out until they were totally clean and free to move (years of accumulated grease apparently were making them stick and hold the switch closed). Make sure all the front panel pushbuttons and slides are totally retracted (ie fully forward on the control panel away from the control board) and reinstall the board, again making sure all the plastic tabs that hold it in place are seated. Just make sure you turn on the power and make sure all the switches still function before sliding the oven back in place, otherwise you'll have to take it apart again like me! Hope this helps someone.
  #3 (permalink)
Old 09-27-2012, 11:22 AM
Junior Member
Default
BTW, got the CRC electronic cleaner from the local auto parts store
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef F3 error code even after temp sensor replacement ponderitsome Oven Repair (including Ranges and Cooktops) 3 07-22-2011 10:24 AM
Magic Chef Electric Wall Oven F1 Code and Beeping OvenFella Oven Repair (including Ranges and Cooktops) 0 12-12-2010 02:55 PM
Magic Chef Oven F3 Fault code Jack2010 Oven Repair (including Ranges and Cooktops) 0 06-23-2010 04:22 AM
F-7 error code magic chef started beeping this A boblf Oven Repair (including Ranges and Cooktops) 6 05-28-2009 01:41 AM
Magic Chef F1 code? happyfeet Oven Repair (including Ranges and Cooktops) 6 04-17-2009 03:42 AM
