Discuss
Oven igniter glows red but does not heat
 in
No heat in oven. Broiler heats fine; stovetop burners work fine. Removed temp sensor probe and tested at 1.09k at
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven igniter glows red but does not heat
  #1 (permalink)
Old 09-25-2012, 05:21 PM
Junior Member
TeamCeisel is on a distinguished road
Default Oven igniter glows red but does not heat
Model Number: JGB920KEC3CC   Brand: GE   Age: More than 10 years
No heat in oven. Broiler heats fine; stovetop burners work fine. Removed temp sensor probe and tested at 1.09k at room temperature. Was instructed to test amps of igniter (should be 3.3-3.6 I was told). Haven't had a chance to test that yet. But, if the amps check out, what is the next step?
Ads By Google
Related Models
General Electric JGB920KEC3CC Gas range
General Electric JGB920KEF1CC Gas range
General Electric JGB920KEF2CC Gas range
General Electric JGB920SEC1SS Gas range
General Electric JGB920SEC2SS Gas range
General Electric JGB920SEC3SS Gas range
General Electric JGB920SEC4SS Gas range
General Electric JGB920SEF1SS Gas range
General Electric JGB920SEF2SS Gas range
General Electric JGB920TEC1WW Gas range
General Electric JGB920TEC2WW Gas range
General Electric JGB920TEC3WW Gas range
General Electric JGB920TEF1WW Gas range
General Electric JGB920TEF2WW Gas range
General Electric JGB920WEC1WW Gas range
General Electric JGB920WEC2WW Gas range
General Electric JGB928BEK1BB Gas range
General Electric JGB928BEK2BB Gas range
General Electric JGB928BEK3BB Gas range
General Electric JGB928BEK4BB Gas range
General Electric JGB928BEK5BB Gas range
General Electric JGB928BEK6BB GAS RANGE
General Electric JGB928KEK1CC Gas range
General Electric JGB928KEK2CC Gas range
General Electric JGB928KEK3CC Gas range
General Electric JGB928KEK4CC Gas range
General Electric JGB928KEK5CC Gas range
General Electric JGB928KEK6CC GAS RANGE
General Electric JGB928SEK1SS Gas range
General Electric JGB928SEK2SS Gas range
General Electric JGB928SEK3SS Gas range
General Electric JGB928SEK4SS Gas range
General Electric JGB928SEK5SS Gas range
General Electric JGB928SEL1SS Gas range
General Electric JGB928SEL2SS GAS RANGE
General Electric JGB928TEK1WW Gas range
General Electric JGB928TEK2WW Gas range
General Electric JGB928TEK3WW Gas range
General Electric JGB928TEK4WW Gas range
General Electric JGB928TEK5WW Gas range
General Electric JGB928TEK6WW GAS RANGE
General Electric JGBC12GEN1 Gas range
General Electric JGBC12GEN2 Gas range
General Electric JGBC15GEK1 Gas range
General Electric JGBC15GEK3 Electric range
General Electric JGBC15GEK4 Gas range
General Electric JGBC15GEN1 Gas range
General Electric JGBC15GEN2 Gas range
General Electric JGBC15GER1 Gas range
General Electric JGBC15GER2 Gas range
General Electric JGBC15GER3 Gas range
General Electric JGBC15GER4 Gas range
General Electric JGBC15GER5 Gas range
General Electric JGBC15GER6 Gas range
General Electric JGBC15GPK1 GE FREE-STANDING / DROP-
General Electric JGBC16GEH1 Electric range
General Electric JGBC16GEH2 Gas range
General Electric JGBC16GEH3 Gas range
General Electric JGBC16GEH4 Gas range
General Electric JGBC16GEJ1 Electric range
General Electric JGBC16GEJ2 Gas range
General Electric JGBC16GEJ3 Gas range
General Electric JGBC16GEJ4 Gas range
General Electric JGBC16GEJ5 Gas range
General Electric JGBC16GEJ6 Gas range
General Electric JGBC16GEJ7 Gas range
General Electric JGBC16GEP1 Gas range
General Electric JGBC16GEP2 Gas range
General Electric JGBC16GEP3 Gas range
General Electric JGBC16GEP4 Gas range
General Electric JGBC16GEP5 Gas range
General Electric JGBC16GEP6 Gas range
General Electric JGBC16GEP7 Gas range
General Electric JGBC16GPH1 Gas range
General Electric JGBC16GPH2 Electric range
General Electric JGBC16GPH3 Gas range
General Electric JGBC16GPJ1 Gas range
General Electric JGBC16GPJ2 Gas range
General Electric JGBC16GPJ3 Gas range
General Electric JGBC16GPJ4 Gas range
General Electric JGBC16GPJ5 Gas range
General Electric JGBC16GPJ6 Gas range
General Electric JGBC17EV1AD Gas range
General Electric JGBC17EV1WH Gas range
General Electric JGBC17EV2AD Gas range
General Electric JGBC17EV2WH Gas range
General Electric JGBC17EV3AD Gas range
General Electric JGBC17EV3WH Gas range
General Electric JGBC17EV4AD Gas range
General Electric JGBC17EV4WH Gas range
General Electric JGBC17GEH1 Gas range
General Electric JGBC17GEH2 Gas range
General Electric JGBC17GEH3 Gas range
General Electric JGBC17GEJ1 Gas range
General Electric JGBC17GEJ2 Gas range
General Electric JGBC17GEJ3 Gas range
General Electric JGBC17GEJ4 Gas range
General Electric JGBC17GEJ5 Gas range
General Electric JGBC17GEK1 Gas range
General Electric JGBC17GEK2 Gas range
General Electric JGBC17GEK3 Gas range
General Electric JGBC17GER1 Gas range
General Electric JGBC17GER2 Gas range
General Electric JGBC17GER3 Gas range
General Electric JGBC17GER4 Gas range
General Electric JGBC17GPH1 Gas range
General Electric JGBC17GPH2 Electric range
General Electric JGBC17GPH3 Gas range
General Electric JGBC17PEA1AD Gas range
General Electric JGBC17PEA1WH Gas range
General Electric JGBC17PEA2AD Gas range
General Electric JGBC17PEA2WH Gas range
General Electric JGBC17PEA3AD Gas range
General Electric JGBC17PEA3WH Gas range
General Electric JGBC17PEW1AD Gas range
General Electric JGBC17PEW1WH Gas range
General Electric JGBC17PEW2AD GAS RANGE
General Electric JGBC17PEW2WH GAS RANGE
General Electric JGBC18EV1WW Gas range
General Electric JGBC18EV2WW Gas range
  #2 (permalink)
Old 09-25-2012, 07:31 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
If the ignitor glows most likely it's not pulling enough amps to open the gas valve. Replace the ignitor
Part number: WB13K21
Here are the breakdown diagrams and Replacement parts for General Electric JGB920KEC3CC Gas range | AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer wont heat (new coils, igniter glows) ajpa Dryer Repair 6 06-01-2012 12:28 PM
igniter glows but no gas, no heat pjgsteelers Dryer Repair 2 03-20-2011 07:12 AM
OVEN WILL NOT IGNITE (but igniter glows) dennis728 Oven Repair (including Ranges and Cooktops) 3 02-08-2011 05:25 PM
Igniter Glows, But Oven Won't Light doitmyself7 Oven Repair (including Ranges and Cooktops) 0 07-09-2010 07:31 PM
Igniter Glows Replaced Coils Still no Heat Friar Dryer Dryer Repair 1 12-05-2008 01:53 PM
