Discuss
Jenn Air element will not come on
 in
I have a Jenn Air Double Electric Wall Oven (model# WW2780W). When you select bake or convection bake for the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air element will not come on
  #1 (permalink)
Old 09-25-2012, 12:50 PM
Junior Member
bjohnson2010 is on a distinguished road
Default Jenn Air element will not come on
Model Number: WW2780W   Brand: Jenn-Air   Age: More than 10 years
I have a Jenn Air Double Electric Wall Oven (model# WW2780W). When you select bake or convection bake for the top oven only the broiler element is turning on and it seems to stay on. Any ideas on why the baking element is not coming on and is the broiler element suppose to be turning on/off while in pre-heat only?
Related Models
Jenn-Air WW2780W WALLOVEN- S/C ELE
Jenn-Air WW2780W-C WALLOVEN- S/C ELE
Whirlpool WW29000SU0 LAUNDRY WORKSURFACE
Whirlpool WW29000SW0 LAUNDRY WORKSURFACE
Jenn-Air WW30110B WALLOVEN- S/C ELE
Jenn-Air WW30110W WALLOVEN- S/C ELE
Jenn-Air WW30430B WALLOVEN- S/C ELE
Jenn-Air WW30430P WALLOVEN- S/C ELE
Jenn-Air WW30430PC WALLOVEN- S/C ELE
Jenn-Air WW30430PF WALLOVEN- S/C ELE
Jenn-Air WW30430PG WALLOVEN- S/C ELE
Jenn-Air WW30430PK WALLOVEN- S/C ELE
Jenn-Air WW30430PR WALLOVEN- S/C ELE
Jenn-Air WW30430PU WALLOVEN- S/C ELE
Jenn-Air WW30430W WALLOVEN- S/C ELE
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
 WW600 MWAVE- CNTRTP / STAND ALONE
General Electric WW8318LAL AUTOMATIC WASHER
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
General Electric WWA5826RBL Washer
General Electric WWA5857RBL Washer
General Electric WWA6007MAL Washer
General Electric WWA6407LBL Washer
General Electric WWA6600MAL Washer
General Electric WWA6600RBL Washer
General Electric WWA6600SALAA Washer
General Electric WWA6600SALWW Washer
General Electric WWA6600SBLAA Washer
General Electric WWA6600SBLWW Washer
General Electric WWA6800SALAD Washer
General Electric WWA6800SALHA Washer
General Electric WWA6800SALWH Washer
General Electric WWA7010GAL Washer
General Electric WWA7010GBL Washer
General Electric WWA7050BAL Washer
General Electric WWA7050GAL Washer
General Electric WWA7050GBL Washer
General Electric WWA7059VCL Washer
General Electric WWA7060VCL Washer
General Electric WWA7070BAL Washer
General Electric WWA7070GAL Washer
General Electric WWA7070GBL Washer
General Electric WWA7070VCL Washer
General Electric WWA7079VCL Washer
General Electric WWA7304PML Washer
General Electric WWA7304VKL Washer
General Electric WWA7304VLL Washer
General Electric WWA7600RBL Washer
General Electric WWA7600SALAA Washer
General Electric WWA7600SALWW Washer
General Electric WWA7600SBLAA Washer
General Electric WWA7600SBLWW Washer
General Electric WWA7619MAL Washer
General Electric WWA7640SALAA Washer
General Electric WWA7640SALWW Washer
General Electric WWA7640SBLAA Washer
General Electric WWA7640SBLWW Washer
General Electric WWA7646MAL Washer
General Electric WWA7650SALAA Washer
General Electric WWA7650SALWW Washer
General Electric WWA7650SBLAA Washer
General Electric WWA7650SBLWW Washer
General Electric WWA7678MAL Washer
General Electric WWA7680SALAA Washer
General Electric WWA7680SALWW Washer
General Electric WWA7680SBLAA Washer
General Electric WWA7680SBLWW Washer
  #2 (permalink)
Old 10-10-2012, 09:11 AM
Junior Member
Default Checked continuity of the bake element
I have checked the continuity of the bake element and that tested out fine. When I turned off the breaker and turned back on the breaker so I could test the continuity the relays in the control board must have somehow reset, because when the power was restored the top oven started working normally again. A few weeks later after several uses the same issue is now occurring (when bake is selected the bake element is not coming on and the broil element stays on) and if you let this go long enough the oven will display the F2 Error code (for overheating). I am assuming I need to replace the Relay Control Board (Y04100260), but if anyone has any input that would be great.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Old Jenn Air needs element Brian LaPlante Oven Repair (including Ranges and Cooktops) 0 01-30-2012 07:49 AM
Jenn-Air (Maytag) Element D Danow Oven Repair (including Ranges and Cooktops) 0 06-17-2011 07:49 AM
Jenn Air Grill Element cardiacpac Oven Repair (including Ranges and Cooktops) 10 02-25-2011 12:19 PM
Jenn Air Element Replacement mjterry Oven Repair (including Ranges and Cooktops) 0 06-26-2010 08:22 AM
jenn-air element wiring breonw@bellsouth.net Heating, Ventilation, and Air Conditioning (HVAC) 1 11-20-2009 08:29 AM
