I have a gas Stove[Magic Chef].It has the electric ignighter.It's been working fine for the 2 years i'm been in this home.All of a sudden it's giving a constant beeping and on the LED screen,it's shows a F-1. When i hit the clear button and hold it.the beep goes off but then comes back on.It's an older model.What's wrong and how can i fix it?
What is the complete model number of the range?
Originally Posted by: Gene What is the complete model number of the range? The model # 34hn 3tkxw
Most likely the problem is a bad control board (aka a clock). If you need the correct part number then post the serial number of the range.
