| » After pre heat oven shuts off |
Model Number: 665.72132300 Brand: Kenmore Age: 5 - 10 years
A self clean cycle was done to the oven, and now the oven shuts off after the it pre-heats. I would have to relight the oven and after a few minutes it would shut off. Could the heat sensor be the issue, and where would I check with an ohm meter ?
Does it shut off completely with the display shows time of the day only or it would not relight only?
Would it do the same thing if you use the Broil? More detailed description on the problem you posted makes easier to diagnose the problem. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
when it shut off, I would ignite the broiler and then switch over to the oven which it would shut off again. Now it the broiler will not ignite. it would try to ignite but nothing happens, just the oven, the time display shows just would not relight
the oven would shut off and try to relight the time of day display stays on. My wife would light the broiler and the switch over to oven at that point it would go out. She told me now either will light, it would try but nothing.
Check the gas valve as instructed in one of our previous threads: Whirlpool Oven won't heat up (post addressed to Jim) and post the results.
__________________
Quote:
I would recommend the Bake burner. It comes together with the igniter as assembly.
- The Bake burner Part number: 8190618 Gene.
__________________
| Display Modes | |
| Amana ACS3350AS - Heat escapes oven door & shuts control panel off | mjp3475 | Oven Repair (including Ranges and Cooktops) | 8 | 11-26-2012 01:12 PM |
| heat shuts off | agalletta | Dryer Repair | 1 | 08-03-2010 05:14 PM |
| Normal Heat Empty, Heat Shuts Off Full | BigDaddyG | Dryer Repair | 4 | 08-06-2009 03:17 PM |
| GE Profile Oven Heat up Too Fast and shuts off | bobf4080 | Oven Repair (including Ranges and Cooktops) | 3 | 12-01-2008 05:40 PM |
| Oven Shuts Off when Pre heat Temp is Reached | peggy1al@MSN.COM | Oven Repair (including Ranges and Cooktops) | 1 | 12-14-2007 01:58 PM |
