My oven will not turn off. Even in off position, the elements remain extremely hot, not even sure at what temp it stays on. Should I turn on. To a set temp to see if any error codes as nothing shows on display. If on, the oven red light will go on. Interesting as the other day, we did turn the dial to oven clean just to see if it would work. We turned off but the problem started shortly thereafter. Could have been 1 day as we just didn't know about oven but then realized a smell of cooking.
Is this a sensor or temp sensor issue? Or is it likely the control panel. When opened it seems to be one big control panel
Lastly would it be an element?
Thank you
