Discuss
One of 2 Oven Ignitors Glows & Lights, Other doesn't
 in
My Viking VGIC365 6BSS Oven only lights on one side (Left). Have 2 new ignitors, and Left Side (facing down
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » One of 2 Oven Ignitors Glows & Lights, Other doesn't
  #1 (permalink)
Old 09-22-2012, 01:49 PM
Junior Member
dachickenfarmer is on a distinguished road
Default One of 2 Oven Ignitors Glows & Lights, Other doesn't
Model Number: VGIC364 6BSS   Brand: -other-   Age: 5 - 10 years
My Viking VGIC365 6BSS Oven only lights on one side (Left). Have 2 new ignitors, and Left Side (facing down when looking from front) of dual safety valve will light either ignitor. Other side of valve doesn't glow.
Voltage into valve is 3.0 into "good" side, 110 into "bad" side.
Is this the selector switch or the valve or something else? If selector switch, what's the part number?
And where is the selector switch??
Thanks!
Panu
Ads By Google
Related Models
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410 HOOD VENTILATOR
Thermador VM-450
Magic Chef VM11A-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8PDY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11BN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11C-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11CN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P-DY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11DN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EB-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EV-8P MWAVE- MOUNTED UNDER CABINET
Maytag VM12AB MWAVE- MOUNTED UNDER CABINET
Maytag VM12AM MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV-1 MWAVE- MOUNTED UNDER CABINET
Thermador VM410
Magic Chef VM9B-8 MWAVE- MOUNTED UNDER CABINET
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000 VENTILATOR
Thermador VQT600 VENTILATOR
Thermador VR-1000 VENTILATOR
Thermador VR-1400 VENTILATOR
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
  #2 (permalink)
Old 11-01-2012, 07:16 PM
Junior Member
VikTech is on a distinguished road
Default
The ignitors are wired in series...power coming straight down from your thermostat. Sounds as if the ignitors are wired incorrectly. Each ignitor should be taking incoming voltage from the wires coming in from the right side of the range. The other wire on the ignitor should be going to the valve. 3A or more are needed to open the valve, so it sounds as if the current is not reaching your valve on the ignitor that's not working. Either failed ignitor or mis-wired.
  #3 (permalink)
Old 11-02-2012, 04:54 AM
Junior Member
Default
Thanks for the reply - I forgot to post - I changed the valve & it worked - 1 of the 2 electrical leads to the valve had an open circuit.
  #4 (permalink)
Old 12-06-2012, 06:04 PM
Junior Member
icarus is on a distinguished road
Default
I have the identical problem. I replaced both igniters last week, and the oven worked fine. When I replaced the igniters I noticed the burners were burned out, so today I replaced these as well. The oven test fired fine, but in the middle of doing dinner, the left igniter is not lighting and the left burner is also then not lighting!
Any great ideas? (I am going to put one of he old igniter back in to see if that work,, going to be upset if the new igniter has failed! ) the old ones were just slow.
Thanks in advance for any help!
Icarus
PS. Putting the old ignitor back in changes nothing. (BTW, the igniters are NOT wired in series, but in PARALELL. ). I get 120 vac through the igniter. I'm hard pressed to believe the gas valve (or more correctly, one side of the valve ) has failed.
I
  #5 (permalink)
Old 12-10-2012, 08:40 PM
Junior Member
Default
Yes you are correct...they are wired in parallel, my mistake not sure what i was drinking that night.
you have 120v going through the igniter but not glowing? Sounds like a bad igniter. The blown through holes on the burners will kill igniters very quickly. The blown out holes are a result of not changing the igniters in time. as they get weak they still glow, and allow the valve to open but not fully. this lack in heat from the igniter causes mini-explosions at the burner ports eventually blowing them out. Changing the igniter and not the burner tube at the same time leads to a larger flame where the ports blew out. Typically reduces the life of the igniter greatly, but a week or two is extreme. I'd imagine you just got a dud of an igniter. New igniters should draw about 3.4 amps...some generic parts draw closer to 3 out of the box. Anything less than 2.9 will give you issues with heating.
  #6 (permalink)
Old 12-10-2012, 10:31 PM
Junior Member
Default
It is worse than that! After I changed the igniters and the burner tubes, I needed to adjust the flame ( too much yellow) As it was almost supper time, I decided to wait for the next day, but we used the oven. What happened (as far as I can tell!) is that the flame carboned up the igniter, causing it to short to the burner tube, which in turn, blew out one half of the gas valve!
A very expensive mistake in not truing the flame properly right away. Known good igniters don't work. I am assuming that the circuit is closed by part of the gas valve.
Unless anybody has any other idea, I am forced, at this point to replace the gas valve. What pisses me off is for the sake of a ten cent fuse that would have protected the gas valve one wouldn't have to go through this.
Thanks for the help.
Icarus
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't light, ignitor glows chinahorse Oven Repair (including Ranges and Cooktops) 3 06-16-2011 07:23 AM
Oven and broiler won't light - neither HSI glows marketforce Oven Repair (including Ranges and Cooktops) 0 07-27-2010 03:42 PM
Igniter Glows, But Oven Won't Light doitmyself7 Oven Repair (including Ranges and Cooktops) 0 07-09-2010 07:31 PM
oven ignitor glows but no gas flows Jack Top Oven Repair (including Ranges and Cooktops) 0 06-22-2010 08:48 AM
Kenmore Gas Dryer Glows, Lights Weakly Intermittently Phil_MMX Dryer Repair 0 04-17-2010 08:49 AM
