Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   GE Hi Lo Cook Center Upper Oven Door Gasket (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/500913-ge-hi-lo-cook-center-upper-oven-door-gasket.html)
czerner 09-21-2012 07:35 AM
I am trying to reassemble the upper oven door after replacing the gasket that protects the rear glass; however, I have an L-shaped bracket that I have no clue where it fits. I tried to note the location of parts; however, when I separated the outer cover, the inner parts popped out.
The door seems to function okay without this part, but I fear that it has a function that will ultimately cause trouble if it's not installed correctly.
I looked at the exploded drawing for the parts, but I don't find the bracket.
Thanks for your help.
Fred
