| » Replacing oven igniter |
Model Number: JGS968TH3WW Brand: GE Age: 1 - 5 years
Just purchased an igniter that will not glow at all. This is a self cleaning oven. Can the igniter connection be acccessed from the inside by removing the bottom burner pan, gas tube and heat shield. Or do I need to remove the rear panels on the back of the range to get access to the stove. The diagrams available do not show where the igniter is plugged into the power source. Any suggestion would be greatly appreciated to make the job easier. Thanks.
| Display Modes | |
| GE Gas Oven will not work even after replacing the Igniter | revbobmartin | Oven Repair (including Ranges and Cooktops) | 0 | 01-21-2010 01:15 PM |
| GE Gas Oven will not work even after replacing the Igniter | revbobmartin | Oven Repair (including Ranges and Cooktops) | 0 | 01-21-2010 01:07 PM |
| GE Gas Oven will not work even after replacing the Igniter | revbobmartin | Oven Repair (including Ranges and Cooktops) | 0 | 01-21-2010 01:03 PM |
| Replacing Oven Igniter | Chowder | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2009 04:29 PM |
| Replacing Igniter | andersom68 | Oven Repair (including Ranges and Cooktops) | 2 | 08-12-2009 04:46 PM |
