Discuss
Oven temperature maintenance
 in
(Very lengthy read) This is a domestic coil (electric) no frills basic Apartment-sized unit like those we have all been
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temperature maintenance
  #1 (permalink)
Old 09-17-2012, 01:40 PM
Junior Member
doomeddanby is on a distinguished road
Default Oven temperature maintenance
Model Number: DER2009W DANBY   Brand: -other-   Age: Less than 1 year
(Very lengthy read)
This is a domestic coil (electric) no frills basic Apartment-sized unit like those we have all been exposed to since the late 1950's. (a Four coil top, 2000 Broiler element, 1900 Bake element). no timer, or oven viewing light . . . "only" an Oven indicator, and a separate top burner light.
One month old, and replacing a GE 24 year-old unit (identical in all ways).
230VAC 40 amp L1/L2 (tested to 35 amp leg load, holding voltage), new construction installation.
Single Oven control knob, 0-600 degree range, plus Broil (in the far right detent position), the Broiler works perfectly.
This "is not" an issue about calibration ! (indicated dial set point-to-actual-oven-temperature) so, please ! do not go there), "indicated temperature" is 20 degrees different from actual at all temperature settings, (and constant, at 200 through 600 degrees).
On attempting my 30 year-old established baking tasks of 45 minutes, I had to accept inferior results after more than 2 full hours baking time. (enter the Engineer).
With a Fluke recorder, and thermocouple (freshly ice set), 0 (70 ambient)-350 "preheat times are 8-12 minutes (small box)... And "that" ends what is good.
The next round went like this:
Achieved 350F…held it for 15 seconds and then started dropping temperature…. Oven Indicator light always ON.
Oven temperature dropped to 250F over 8:00 elapsed minutes… held steady for 10 seconds, and then began rising in temperature. Oven Indicator light always ON. Broiler element not active.
3 minutes 55 seconds (250F to 350F), Broiler element not active, Oven Indicator light always ON, held at 350F for 15 or so seconds and began dropping again.
Oven temperature dropped to 250F over 8:28 elapsed minutes … held there for a moment, and then, began rising in temperature again. Indicator light always ON, Top element not active.
3 minutes 50 seconds (250F to 350F) Broiler element not active, Oven Indicator light always ON, held at 350F for 10 seconds and began dropping again.
I ran six test cycles . . . (all were data mimics of these earlier events), so, I called the Manufacturer, they have no technical support, so, they refer everything to their Professional Service/Warranty field people. Whom I contacted, and they came out to service the unit at my home.
The Veteran Serviceman advised me that "all ovens swing in temperature, you don't just set it at 350 and expect it to stay there !" I responded with "a 100 degree swing ? "oh yes, 100 degrees on either side of your "set point".
The actual argument drew into why the Oven Indicator Light does not go off on attaining set point.. I learned "these are Power on Indicators only, Oven lights don't go out when they reach temperature" and later " the Broiler element has absolutely nothing to do with baking, that's why they are called 'Broiler' elements !" But, he said "the oven "set point" was off from what was actually going on inside, so, he would order another Oven Control Assembly".
He furthered the issue by saying "the Owners Manual is wrong, Ovens never worked that way, and this one wont either"
I was foaming at the mouth, the old GE unit, and my daughters Westinghouse ... and the Owners Manual for this unit ALL show the schematic, and explain the operation sequence clearly, in my old RobertShaw/Honeywell Controls days we held temps within 15-20 degrees of set point, and Oven indicator lights (and Broiler elements on 115) cycled as required.
Is this no longer 21st Century valid ? what should one expect from their Oven Control for temperature maintenance around a given set-point ? I doubt this unit is American made, and the Factory ? in Ohio may just be a sales outlet/importer, so, I am hoping to proceed on my own.
Ads By Google
Related Models
Frigidaire DES100CD1 Kel(v2) / Electric Dryer
Frigidaire DES100CW1 Kel(v1) / Electric Dryer
Frigidaire DES100FD2 Kel(v2) / 27 " Dryer
Frigidaire DES100FW2 Kel(v1) / 27 " Dryer
Amana DES11E Commercial Microwaves
Menu Master DES11EA  Commercial Microwaves
Frigidaire DESFL0 Frg(v6) / Electric Dryer
Frigidaire DESFL1 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFL3 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFL4 Frg(v6) / 27 " Electric Dryer
Frigidaire DESFW0 Frg(v5) / Electric Dryer
Frigidaire DESFW1 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW2 Frg(v3) / 27 " Electric Dryer
Frigidaire DESFW3 Frg(v5) / 27 " Electric Dryer
Frigidaire DESFW4 Frg(v5) / 27 " Electric Dryer
Frigidaire DET100KD1 Kel(v4) / 27 " Electric Dryer
Frigidaire DET100KD2 Kel(v4) / 27 " Electric Dryer
Frigidaire DET100KW1 Kel(v3) / 27 " Electric Dryer
Frigidaire DET100KW2 Kel(v3) / 27 " Electric Dryer
Frigidaire DET250K1D Kel(v2) / 27 " Electric Dryer
Frigidaire DET250K1W Kel(v1) / 27 " Electric Dryer
Frigidaire DET400A0D Kel(v8) / Dryer
Frigidaire DET400A0T Kel(v9) / Dryer
Frigidaire DET400A0W Kel(v10) / Dryer
Frigidaire DET400A1D Kel(v9) / Dryer
Frigidaire DET400A1T Kel(v10) / Dryer
Frigidaire DET400A1W Kel(v11) / Dryer
Frigidaire DET400A2D Kel(v9) / Electric Dryer
Frigidaire DET400A2T Kel(v10) / Electric Dryer
Frigidaire DET400A2W Kel(v11) / Electric Dryer
Frigidaire DET400F1D Kel(v12) / Electric Dryer
Frigidaire DET400F1J Kel(v11) / Electric Dryer
Frigidaire DET400F1W Kel(v10) / Electric Dryer
Frigidaire DET400F2D Kel(v11) / Electric Dryer
Frigidaire DET400F2J Kel(v12) / Electric Dryer
Frigidaire DET400F2W Kel(v10) / Electric Dryer
Frigidaire DET400G1D Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G1J Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G1W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G2D Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G2J Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G2W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G3D Kel(v8) / 27 " Electric Dryer
Frigidaire DET400G3J Kel(v9) / 27 " Electric Dryer
Frigidaire DET400G3W Kel(v7) / 27 " Electric Dryer
Frigidaire DET400G4D Kel(v6) / 27 " Electric Dryer
Frigidaire DET400G4W Kel(v5) / 27 " Electric Dryer
Frigidaire DET400KD1 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KD2 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KD3 Kel(v2) / 27 " Electric Dryer
Frigidaire DET400KW1 Kel(v1) / 27 " Electric Dryer
Frigidaire DET400KW2 Kel(v1) / 27 " Electric Dryer
Frigidaire DET400KW3 Kel(v1) / 27 " Electric Dryer
Maytag DF10AALWH Freezer - Vertical
Maytag DF10ABLWH Freezer - Vertical
Maytag DF10ABLWHT Freezer - Vertical
Maytag DF10BBLWHT  Freezer - Vertical
Amana DF110 Freezer - Chest
Amana DF110A Mwave - Cntrtp / Stand Alone
Amana DF110D Mwave - Cntrtp / Stand Alone
Maytag DF12ABLWH Freezer - Vertical
Maytag DF12ACLWH Freezer - Vertical
Maytag DF12ACLWHT Freezer - Vertical
Maytag DF12BCLWHT  Freezer - Vertical
Maytag DF12H  Freezer - Vertical
Maytag DF12J Freezer - Vertical
Maytag DF15AAL-WH Freezer - Vertical
Maytag DF15ABLWH Freezer - Vertical
Maytag DF15ACLWH Freezer - Vertical
Maytag DF15ADLWH Freezer - Vertical
Maytag DF15ADLWHT Freezer - Vertical
Maytag DF15ASLWH Freezer - Vertical
Maytag DF15ATLWH Freezer - Vertical
Maytag DF15ATLWHT Freezer - Vertical
Maytag DF15AUMALT Freezer - Vertical
Maytag DF15AUMWHT Freezer - Vertical
Maytag DF15BDLWHT  Freezer - Vertical
Maytag DF15BE  Freezer - Vertical
Maytag DF15BPB  Freezer - Vertical
Maytag DF15BTLWHT  Freezer - Vertical
Maytag DF15BUMALT  Freezer - Vertical
Maytag DF15BUMWHT Freezer - Vertical
Maytag DF15H Freezer - Vertical
Maytag DF15HG Freezer - Vertical
Maytag DF15HS Freezer - Vertical
Maytag DF15HX Freezer - Vertical
Maytag DF15J Freezer - Vertical
Maytag DF15JG Freezer - Vertical
Amana DF160 Freezer - Chest
Amana DF160-1 Freezer - Chest
Amana DF160A Freezer - Chest
Amana DF170 Freezer - Chest
Maytag DF17AALWH Freezer - Vertical
Maytag DF17ABLWH Freezer - Vertical
Maytag DF17ACLWH Freezer - Vertical
Maytag DF17ACLWHT Freezer - Vertical
Maytag DF17BCLWHT  Freezer - Vertical
Maytag DF17BPB  Freezer - Vertical
Amana DF180 Freezer - Chest
Amana DF180A Mwave - Cntrtp / Stand Alone
Amana DF180B Mwave - Cntrtp / Stand Alone
Maytag DF20AALWH Freezer - Vertical
Maytag DF20ABLWH Freezer - Vertical
Maytag DF20ACLWH Freezer - Vertical
Maytag DF20ACLWHT Freezer - Vertical
Maytag DF20BCLWHT  Freezer - Vertical
Maytag DF20H  Freezer - Vertical
Maytag DF20HX  Freezer - Vertical
Maytag DF20J Freezer - Vertical
Amana DF220 Freezer - Chest
Amana DF220A Freezer - Chest
Amana DF240 Freezer - Chest
Amana DF240A Mwave - Cntrtp / Stand Alone
Amana DF240B Mwave - Cntrtp / Stand Alone
Amana DF90 Freezer - Chest
Amana DF90A Freezer - Chest
Maytag DFB1100AAX Disposal
Maytag DFB1100ABX Disposal
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maintenance man tagm Washer Repair 2 11-10-2011 02:14 PM
Maintenance Jhorn49168 Refrigerator & Freezer Repair 1 07-28-2011 01:11 PM
Built-in Microwave/Oven Combo Maintenance JimLocus Oven Repair (including Ranges and Cooktops) 0 11-20-2009 01:34 PM
Maintenance Man MAINTENANCE MAN Oven Repair (including Ranges and Cooktops) 1 10-26-2009 06:29 PM
maintenance carl weist Dishwasher Repair 1 03-07-2008 02:01 PM
