| » Bad results with baking |
Model Number: 79047893604 Brand: Kenmore Age: 1 - 5 years
My Kenmore Elite oven is not baking properly. It would not heat to set temp. I adjusted the temp using instructions in the owners manuel. My results were...It took about 40 minutes to heat to 375. The cookies I baked were over brown on the outside, more or less depending on the location on the cookie sheet. I had a technician check the oven. His answer was the control pad was bad and needed replaced. I am not comfortable with this answer, considering the age of the oven, so I am exploring second opinions. Thanks
Replacement parts for Kenmore 79047893604 by Kenmore Elite | AppliancePartsPros.com I also went to the Sears parts site. They have actual part's breakdowns and a wiring diagram. Unfortunately they like to keep the breakdowns is house. Also the wiring diagram is not very legible so I am doing some guessing here. The unit has a thermal breaker (switch) mounted to the back outside of the oven. It could be that this kills power to on of the elements. It is re-settable, the little nub between the contacts pops out, see below. Part number: AP2126993 Click on the part's picture for more info. Be sure to unplug the unit when working on it!!
__________________
| Display Modes | |
| Icemaker not working, weird voltage results | Dan T in SD | Refrigerator & Freezer Repair | 0 | 05-31-2012 11:51 AM |
| results of sensor testing | Toy862 | Oven Repair (including Ranges and Cooktops) | 9 | 12-06-2011 12:41 PM |
| earth/insulation test results | keithy | Washer Repair | 0 | 11-03-2010 05:56 AM |
| Dryer: No Heat: Troubleshooting Results | jeffsuwanee | Dryer Repair | 1 | 07-24-2009 07:39 AM |
