Discuss
Maytag gas oven won't ignite
 in
Hello, I have a Maytag Gemini Double Oven. The model number is MGR6751BDB. The problem started when the oven would
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag gas oven won't ignite
  #1 (permalink)
Old 09-12-2012, 08:03 PM
Junior Member
peterburns is on a distinguished road
Default Maytag gas oven won't ignite
Model Number: MGR6751BDB   Brand: Maytag   Age: 1 - 5 years
Hello,
I have a Maytag Gemini Double Oven. The model number is MGR6751BDB. The problem started when the oven would trip the circuit breaker and shut down. First, I replaced the breaker thinking that might be the problem...it wasn't. Next I replaced the circuit board in the oven (part #W10166969). When I installed the board and turned the oven back on, there was a loud pop and smoke rose up. I thought I had fried the board, but when I got into the oven and looked I found that the igniter wires had been pinched between the sheet metal body of the oven and had shorted out (This was the problem all along and the short had apparently been made worse when I changed the board).
I replaced the igniter and tried the oven again. Now it stays at 105 degrees and will not light or do anything. I swaped out the circuit board (to the original) and still it is the same as the first board(105 degrees). I then pulled the thermostat and tested it for resistance and it was in spec. I am at a loss for the problem. It's like it's in safety mode or in a locked down state that needs to be reset. Do you know where the problem might lie?
Related Models
Maytag MGR6751BDB FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6751BDB18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6751BDB19 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6751BDS FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6751BDS18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6751BDS19 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6751BDW FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6751BDW17 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6751BDW18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6751BDW19 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6772BDB FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6772BDQ FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6772BDS FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6772BDW FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775ADB FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775ADQ FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775ADS FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775ADW FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775BDB FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775BDB13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDB18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDB19 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDQ FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775BDQ13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDQ17 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDQ18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDS FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775BDS19 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6775BDS20 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER NO
Maytag MGR6775BDW FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6775BDW13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDW18 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6775BDW19 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6875ADB FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6875ADB26 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6875ADB27 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER Co
Maytag MGR6875ADQ FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6875ADS FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6875ADS27 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR6875ADS28 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR6875ADW FREESTANDING-DOUBLE OVEN-GAS
Maytag MGR6875ADW27 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR6875ADW28 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WB2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WS2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7661WW2 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7662WW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7665WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7665WB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7665WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7665WS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7665WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7665WW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7775WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7775WB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7775WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7775WS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7775WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR7775WW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER
Maytag MGR8670WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8670WW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8772WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8772WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8772WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8875WB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8875WB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8875WS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8875WS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8875WW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGR8875WW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CO
Maytag MGRH752BDB RANGE- S/C F/S GAS
Maytag MGRH752BDQ RANGE- S/C F/S GAS
Maytag MGRH752BDS RANGE- S/C F/S GAS
Maytag MGRH752BDW RANGE- S/C F/S GAS
Maytag MGRH752CDS RANGE- S/C F/S GAS
Maytag MGRH865QDB0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDB1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDB10 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDB11 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDB12 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDB13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDQ0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDQ1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDQ10 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDQ11 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDQ12 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDQ13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDS0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDS10 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDS11 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDS12 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDS14 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDW0 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDW1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDW10 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDW11 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDW12 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRH865QDW13 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
Maytag MGRL752BDB RANGE- S/C F/S GAS
Maytag MGRL752BDB14 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER CONVECTION
  #2 (permalink)
Old 09-13-2012, 12:53 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
If the bake ignitor doesn't glow check the gas valve coil. If it's open - replace it Part number: 74011290
Here are the breakdown diagrams and Replacement parts for Maytag MGR6751BDB FREESTANDING-DOUBLE OVEN-GAS | AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-22-2012, 07:36 AM
Junior Member
Hi Simon,
Thanks for your help. The igniter doesn't glow, but it is not the gas valve coil. So far, it is not the gas valve coil, igniter, thermostat or the circuit board. I seem to be running out of things that it could be, do you have any other ideas?
  #4 (permalink)
Old 09-25-2012, 11:49 AM
Expert
Default
Hi.
Have you check the voltage output from the control board?
Are you getting 120VAC to the safety gas valve?
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't ignite; front burners won't ignite SweetMary Oven Repair (including Ranges and Cooktops) 0 07-25-2011 12:32 PM
Maytag DG 303 would ignite klingenfelter Dryer Repair 0 05-08-2011 07:31 AM
Maytag oven won't ignite surveyor81 Oven Repair (including Ranges and Cooktops) 0 04-16-2011 07:11 PM
maytag gas oven boiler and oven will not ignite joe319 Oven Repair (including Ranges and Cooktops) 0 02-08-2010 07:49 AM
Maytag Gas Oven.....Surface Burners ALL Ignite..... Tony D. Oven Repair (including Ranges and Cooktops) 6 12-21-2007 11:08 AM
