| » Error codes |
Model Number: GLES389FSB Brand: Frigidaire Age: 1 - 5 years
Got error code F30. I think that means F3 & F0.Which should I try replacing first? RTD or EOC?
Thanks Ads By Google Related Models |
Replacement parts for Frigidaire GLES389FSB Frigidaire/electric Range | AppliancePartsPros.com Here is a wiring diagram http://manuals.frigidaire.com/prodin.../318271934.pdf F30 is an open oven sensor (probe) Unplug the unit and the sensor at the control board. Measure it with a meter should be about 1100 ohms. If infinite ohms (open) check the thermal circuit breakers, see Section 4. Some of theses are resettable with the pin that pops up between the connection lugs. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| Error Codes | wldaniels | Washer Repair | 1 | 11-22-2011 06:36 PM |
| error codes | isaaclm | Oven Repair (including Ranges and Cooktops) | 0 | 04-01-2011 05:55 AM |
| Whirlpool Codes? Do not seem to be error codes | taranewblue | Oven Repair (including Ranges and Cooktops) | 4 | 06-21-2010 06:21 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| F4, F2 Error codes | kschmid | Oven Repair (including Ranges and Cooktops) | 0 | 04-03-2009 04:12 PM |
