| » GE electric range top shorted out |
Model Number: jcs57y1ww Brand: GE Age: More than 10 years
One of the electric range top burners shorted out and sent sparks flying. Now none of the elec burners work. The Oven heats up but only to 150 degrees. The clock goes on and off when turning the oven on and off.
I check power and everything is still getting power. Volts at least. Not sure about amperage. Not sure if I should just replace all the burners switches and both the oven switch and thermostat or not. Looks like when the burner was shorting it could have zapped pretty much everything. Not sure. Are there any electrical schematics avialable anywhere? Any advice would be helpful thank you Bri Ads By Google Related Models |
Hi.
Unplug the range, disconnect the shorted burner switch (mark the wires) and try if the rest of them working. Make sure there is 240VAC to the range. Here are the breakdown diagrams and Replacement parts for General Electric JCS57Y1WW Electric range | AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| electric range | pteubel | Oven Repair (including Ranges and Cooktops) | 1 | 10-26-2009 07:22 PM |
| LG Electric Range | lsypien | Oven Repair (including Ranges and Cooktops) | 0 | 10-25-2009 05:15 PM |
| electric range | stoveless45 | Oven Repair (including Ranges and Cooktops) | 0 | 10-22-2008 09:20 AM |
| electric range | dot loughner | Oven Repair (including Ranges and Cooktops) | 6 | 06-19-2008 12:01 PM |
| Electric range | mamu | Oven Repair (including Ranges and Cooktops) | 0 | 04-03-2008 11:40 AM |
