| » Xfe361lvb Oven Wont Heat,no Error Codes |
Model Number: xfe361lvb Brand: Whirlpool Age: 1 - 5 years
My oven is a year and a half old. the stove works bit the oven dont. im gettin no error codes.elements wont heat in bake broil or clean cycles. i have powee to elements when thesw settings are on but no heat.i am getting continuity on my elements...i am puzzled. please help me....thanks..
Ads By Google Related Models Last edited by awvufan76 : 09-16-2012 at 04:40 PM. Reason: wrong model # |
Hi.
Please check the model number and manufacturer, the one you provided doesn't come up. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Still missing one number after B. Are you getting 240VAC to the elements? Please explain how do you measure the voltage. Simon
__________________
Hi.
If there is no bake or broil most likely the thermal fuse is blown Part number: 3196548 It's not very clear where is it (the diagram is not the best) but I think you should look under the top, behind the door latch. the video clip take you to the back of the range...you may check it too. Here are the breakdown diagrams and Chassis parts for Whirlpool WFE381LVS1 - AppliancePartsPros.com It's #26. Simon. Good luck. Post the results.
__________________
Thanks so much for your quick reply. I recognize that part...it's on the back side of the unit. I already had the back panel off trying to see if there were any wires that looked like they had shorted out and I remember seeing this particular piece on the back. Do you know what the ohms reading should be on the thermal fuse to determine if it's good or bad?
Hi.
Take one wire off the fuse when checking. You should read 0ohm.If it's open - replace it. Simon.
__________________
HI.
If the fuse is good you need a control board/clock Part number: W10271740 For the white panel use W10271739 Simon.
__________________
| Display Modes | |
| oven error codes | fred jacoby | Oven Repair (including Ranges and Cooktops) | 1 | 04-04-2012 01:50 PM |
| whjirlpool oven won't heat and gets error codes E-1 F-1 | tmlscm | Oven Repair (including Ranges and Cooktops) | 3 | 03-24-2012 11:43 AM |
| Oven error codes F3 and F2 | emidgette | Oven Repair (including Ranges and Cooktops) | 1 | 06-02-2010 04:54 AM |
| GE oven error codes | bdeinhardt@aol.com | Oven Repair (including Ranges and Cooktops) | 5 | 07-03-2009 11:41 AM |
| No error codes, no heat from oven, ignitors on stovetop non-op | rvaeponce | Oven Repair (including Ranges and Cooktops) | 6 | 11-15-2008 09:26 AM |
