Discuss
Jenn Air double wall oven problems
 in
We have a double wall unit Jenn Air range....for a while now the lower unit would show a 'Fr' fault
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air double wall oven problems
  #1 (permalink)
Old 09-12-2012, 06:43 AM
Junior Member
jetdoc is on a distinguished road
Default Jenn Air double wall oven problems
Brand: Jenn-Air   Age: 5 - 10 years
We have a double wall unit Jenn Air range....for a while now the lower unit would show a 'Fr' fault when turned on. The upper one worked fine until recently.
About a week ago it seemed to be taking a long time for the oven to get to pre heat selected temps..but didn't pay a lot of attention to it. Then this morning when trying to use upper oven we selected the temp and it just showed 100 degrees and never got hot....I tried the broiler and same thing, didn't work.
So now we have two probs, 'Fr' fault on lower unit and upper one oven and broiler do not work.
Any help? I think Fr means a circuit board? Thanks in advance.
Ads By Google
  #2 (permalink)
Old 09-12-2012, 10:10 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Please provide the complete model number of the oven.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-12-2012, 05:08 PM
Junior Member
Default
Hey, ok...at work, will later this evening when I get home.
  #4 (permalink)
Old 09-12-2012, 08:19 PM
Junior Member
Default
Ok here it is.....
WW 274308 is the model number
  #5 (permalink)
Old 09-13-2012, 03:06 PM
Expert
Default
Hi.
To take care of the upper oven problem you need to replace the upper relay board Part number: 74006612
For the lower oven first check the resistance of the oven sensor. With the multimeter set to 10 Kohm at room temperature normal reading about 1100 ohm. if the sensor checks OK - replace the lower oven relay board
Part number: 12001914
Oven sensor Part number: 12001656
Here are the breakdown diagrams and Replacement parts for Jenn-Air WW27430B WALLOVEN- S/C ELE | AppliancePartsPros.com
Post the results.
Simon.
__________________
  #6 (permalink)
Old 09-13-2012, 03:44 PM
Junior Member
Default
Wow, thank you so much Simon..I will let you know the results...
  #7 (permalink)
Old 09-18-2012, 05:12 AM
Junior Member
Default
Ordered the upper board, not sure where its is located...do I have to pull oven out?
The lower, yes it needs a new board as well, the element test ok.
So any help on the location of board would be great.
  #8 (permalink)
Old 09-18-2012, 10:14 AM
Expert
Default
Hi.
Most likely you should remove the oven and open the top. The relay boards are on the side walls (wall). The upper board has more relays in it.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air WW27430B double wall oven jmrobles Oven Repair (including Ranges and Cooktops) 1 03-03-2012 10:24 AM
Jenn-Air double wall oven Leo310 Oven Repair (including Ranges and Cooktops) 1 01-14-2011 07:25 AM
Jenn Air Double Wall Oven slcapehart@windstream.net Oven Repair (including Ranges and Cooktops) 5 01-14-2010 08:11 PM
Jenn-Air double wall oven Donenrico Oven Repair (including Ranges and Cooktops) 1 09-03-2009 05:46 PM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
