Discuss
Oven (Bake) mode quits-goes to Broil
 in
(I'm on a Propane tank.) I saw another (2010) post whereas the question was similiar; last night I used the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven (Bake) mode quits-goes to Broil
  #1 (permalink)
Old 09-11-2012, 08:35 AM
PET PET is offline
Junior Member
PET is on a distinguished road
Default Oven (Bake) mode quits-goes to Broil
Model Number: arg7302ww   Brand: Amana   Age: More than 10 years
(I'm on a Propane tank.) I saw another (2010) post whereas the question was similiar; last night I used the bake mode (350Dg.), and after an hour or so I heard it beeping, saw an F2 in the display, followed by it going back to the time-clock, then the (red) oven light started blinking. A minute or so later the Broiler lit. I turned it off and a minute or so later tried to re-lite the bake; as it was already preheated, it beeped three times indicating so, then the broiler lit again. Because of the age of this, is it worth fixing and fixing (this is my second repair) and/or is this "control Panel", P/N AP4041660 (1.) going to fix my problem and (2.) is it going to be the heart of all other major costs/problems? Many Thanks, pt
Ads By Google
Related Models
Amana ARG7302WW Range - S/c S/i Ddraft Gas
Amana ARG7303CC Range - S/c F/s Gas
Amana ARG7303LL Range - S/c F/s Gas
Amana ARG7303WW Range - S/c F/s Gas
Amana ARG7600CC Range - S/c S/i Ddraft Gas
Amana ARG7600L Range - S/c F/s Gas
Amana ARG7600LL Range - S/c S/i Ddraft Gas
Amana ARG7600W Range - S/c S/i Ddraft Gas
Amana ARG7600WW Range - S/c S/i Ddraft Gas
Amana ARG7800CC Range - S/c S/i Ddraft Gas
Amana ARG7800E Range - S/c S/i Ddraft Gas
Amana ARG7800LL Range - S/c S/i Ddraft Gas
Amana ARG7800SS Range - S/c S/i Ddraft Gas
Amana ARG7800WW Range - S/c S/i Ddraft Gas
Amana ARGS7650CC Range - S/c S/i Ddraft Gas
Amana ARGS7650E Range - S/c S/i Ddraft Gas
Amana ARGS7650LL Range - S/c S/i Gas
Amana ARGS7650SS Range - S/c S/i Gas
Amana ARGS7650WW Range - S/c S/i Gas
  #2 (permalink)
Old 09-11-2012, 11:13 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The F2 code means over temperature sensed. Check the oven sensor resistance. Set the multimeter for 10 Kohm and at room temperature normal resistance should be about 1100 ohm. If it's off - replace the sensor
Part number: Y0314907
If the reading is OK, check the connection to the control board and if needed - replace the board
Part number: 31864501
Here are the breakdown diagrams and Replacement parts for Amana ARG7302WW RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Oven will not heat in bake/broil mode spdkillz Oven Repair (including Ranges and Cooktops) 1 07-11-2012 02:34 PM
Oven does not heat up in Bake mode MWS Oven Repair (including Ranges and Cooktops) 0 02-12-2011 02:18 PM
Broil element turns on in bake mode glenndott Oven Repair (including Ranges and Cooktops) 0 05-03-2010 10:37 AM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
Oven will not heat in bake mode Fred Ventress Oven Repair (including Ranges and Cooktops) 3 08-22-2009 08:39 AM
