| » Oven controller |
Model Number: fes366ecc Brand: Frigidaire Age: 5 - 10 years
How do I check the pinouts on the oven controller? neither the bake or broiler element work so I'm guessing something in the controller. I need pin outs and what readings should be.
Replacement parts for Frigidaire FES366ECC Frigidaire/electric Range | AppliancePartsPros.com Here is your wiring diagram. http://manuals.frigidaire.com/prodin.../318271907.pdf Since it is usually pretty tight in the control panel area I personally do not like doing live tests in this area. Too large a possibility of a arc/spark and/or getting hurt. I would unplug the unit and check the wires to the board and to the elements using resistance/ohms. Also disconnect the oven sensor at the board and check it. It should be around 1100 ohms. This circuit has a circuit breaker in it that may have popped. I am not sure if the control board would give an error if it sees an open sensor so perhaps that is the problem re: it thinks the unit is already at high heat so does not turn on the elements. I am also not sure but some of theses breakers have a button between the connectors that pops out so they can be reset. If everything checks OK I would replace the control.
__________________
| Display Modes | |
| GE Oven Controller / panel or Other? | wiredhernandez | Oven Repair (including Ranges and Cooktops) | 0 | 08-19-2011 05:34 AM |
| oven only heats to ~150 but controller says it is 400 | MRO1MIKE | Oven Repair (including Ranges and Cooktops) | 1 | 02-14-2010 03:21 AM |
| Part # for Maytag oven - controller | barbboy | Oven Repair (including Ranges and Cooktops) | 1 | 10-12-2009 09:40 AM |
| GE oven controller replacement | Edyer | Oven Repair (including Ranges and Cooktops) | 0 | 04-27-2009 04:20 PM |
| Oven controller broken | browndiva | Oven Repair (including Ranges and Cooktops) | 3 | 07-22-2008 01:57 PM |
