| » Whirlpool oven error codes |
Model Number: PBS305PDQ8 Brand: Whirlpool Age: 5 - 10 years
My oven after a power failure shows codes EO FO and will not longer heat. What does this mean and is it a part that is easily replaced?
Hi.
Please check the model number, the one you've posted not coming up. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I don't believe there is F0 E0 code exists. Please double check it.
Simon.
__________________
Unless the bottom number is being cut off, that is what is showing--when the power came back on, it automatically turned on and the only way I could turn it off was at the breaker. So when I turned it back on a couple days later to cook, it turns on, but will not heat. Maybe it is an 8, but the number is cut in half???? I'll run check it again and see. Thank U!!
Hi.
Also there is no code grater then F6. Simon.
__________________
Hi.
Most likely the control board should be replaced Part number: 8186024 Here are the breakdown diagrams and Replacement parts for Whirlpool RBS305PDQ8 ELECTRIC OVEN | AppliancePartsPros.com Simon. PS. You can return any parts even if they been installed.
__________________
| Display Modes | |
| Whirlpool Double Oven Error Codes E1 & F5 | mlindsey3418 | Oven Repair (including Ranges and Cooktops) | 0 | 03-23-2011 06:15 AM |
| Whirlpool Electic oven error codes | fcarrelli | Oven Repair (including Ranges and Cooktops) | 9 | 09-23-2010 06:20 AM |
| Whirlpool Double Oven Error Codes | alaucks | Oven Repair (including Ranges and Cooktops) | 2 | 01-15-2009 09:31 PM |
| Error Codes Whirlpool Oven | brummel | Oven Repair (including Ranges and Cooktops) | 0 | 08-25-2008 12:27 PM |
| Whirlpool Double Oven RBD276PDB12 Error Codes | fishnugget | Oven Repair (including Ranges and Cooktops) | 5 | 07-25-2008 02:56 PM |
