Discuss
double oven appears to have no power
 in
Oven Has No Power Ads By Google Related Models Whirlpool  RBD305PDQ11   Whirlpool  RBD305PDQ12   Whirlpool  RBD305PDQ13   Whirlpool  RBD305PDQ14
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » double oven appears to have no power
  #1 (permalink)
Old 09-05-2012, 12:05 PM
Junior Member
KEVIN64 is on a distinguished road
Default double oven appears to have no power
Model Number: RBD305PDQ11   Brand: Whirlpool   Age: 5 - 10 years
Oven Has No Power
Ads By Google
Related Models
Whirlpool RBD305PDQ14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDQ2
Whirlpool RBD305PDQ3
Whirlpool RBD305PDQ4
Whirlpool RBD305PDQ6
Whirlpool RBD305PDQ7
Whirlpool RBD305PDQ8
Whirlpool RBD305PDQ9
Whirlpool RBD305PDS12
Whirlpool RBD305PDS14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDS15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT11
Whirlpool RBD305PDT12
Whirlpool RBD305PDT13
Whirlpool RBD305PDT14 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PDT15 30" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRB00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRQ00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRS00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD305PRT00 24" Built - in Electric Double Oven Std - Clean Lower Self - Clean Upper
Whirlpool RBD306PDB1
Whirlpool RBD306PDB10
Whirlpool RBD306PDB11
Whirlpool RBD306PDB12
Whirlpool RBD306PDB13
Whirlpool RBD306PDB14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDB2
Whirlpool RBD306PDB4
Whirlpool RBD306PDB6
Whirlpool RBD306PDB7
Whirlpool RBD306PDB8
Whirlpool RBD306PDB9
Whirlpool RBD306PDQ1
Whirlpool RBD306PDQ10
Whirlpool RBD306PDQ11
Whirlpool RBD306PDQ12
Whirlpool RBD306PDQ13
Whirlpool RBD306PDQ14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDQ2
Whirlpool RBD306PDQ4
Whirlpool RBD306PDQ6
Whirlpool RBD306PDQ7
Whirlpool RBD306PDQ8
Whirlpool RBD306PDQ9
Whirlpool RBD306PDT11
Whirlpool RBD306PDT12
Whirlpool RBD306PDT13
Whirlpool RBD306PDT14 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDT15 30" Built - in Electric Double Oven Self - Clean Upper and Lower Ovens
Whirlpool RBD306PDZ1
Whirlpool RBD306PDZ10
Whirlpool RBD306PDZ2
Whirlpool RBD306PDZ4
Whirlpool RBD306PDZ6
Whirlpool RBD306PDZ7
Whirlpool RBD306PDZ8
Whirlpool RBD306PDZ9
Whirlpool RBD307PDB1
Whirlpool RBD307PDB2
Whirlpool RBD307PDQ1
Whirlpool RBD307PDQ2
Whirlpool RBD307PDQ4
Maytag RBE170PA  Ref - Top Mount
Maytag RBE170PW  Ref - Top Mount
Maytag RBE170TA Ref - Top Mount
Maytag RBE170TM Ref - Top Mount
Maytag RBE170TV Ref - Top Mount
Maytag RBE170TW Ref - Top Mount
Maytag RBE17KA-0A  Ref - Top Mount
Maytag RBE17KN-0A  Ref - Top Mount
Maytag RBE193PA  Ref - Top Mount
Maytag RBE193PW  Ref - Top Mount
Maytag RBE193TA Ref - Top Mount
Maytag RBE193TM Ref - Top Mount
Maytag RBE193TV Ref - Top Mount
Maytag RBE193TW Ref - Top Mount
Maytag RBE19KA-3A  Ref - Top Mount
Maytag RBE19KN-3A  Ref - Top Mount
Maytag RBE19KY-3A  Ref - Top Mount
Maytag RBE214AFM Ref - Top Mount
Maytag RBE214AFV Ref - Top Mount
Maytag RBE214RFA  Ref - Top Mount
Maytag RBE214RFV  Ref - Top Mount
Maytag RBE214TFA Ref - Top Mount
Maytag RBE214TFM Ref - Top Mount
Maytag RBE214TFV Ref - Top Mount
Maytag RBE21KA-4AF  Ref - Top Mount
Maytag RBE21KA4AF  Ref - Top Mount
Maytag RBE21KN-4AF  Ref - Top Mount
Maytag RBE21KN4AF  Ref - Top Mount
Frigidaire RBF136CL Frg(v1) / Electric Cooktop
Frigidaire RBF139CE1 Frg(v1) / Cooktop
Frigidaire RBF139CE2 Frg(v1) / Cooktop
Amana RBG322T Mwave - Cntrtp / Stand Alone
Amana RBG322T1 Mwave - Cntrtp / Stand Alone
Amana RBG358P Mwave - Cntrtp / Stand Alone
Amana RBG622T Mwave - Cntrtp / Stand Alone
Amana RBG635T Mwave - Cntrtp / Stand Alone
Frigidaire RBGF119E1 BLACK Frg(v8) / Electric Cooktops and Control Box
Frigidaire RBGF119EL1 Frg(v7) / Electric Cooktops and Control Box
Frigidaire RBGF119EW1 Frg(v6) / Electric Cooktops and Control Box
Amana RBK22AA0 Range - S/i Std Gas
Amana RBK22AA093M Range - S/i Std Gas
Amana RBK22AA5 Range - S/i Std Gas
Amana RBK22AAL Range - S/c S/i Ddraft Gas
Amana RBK22AAW Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 09-06-2012, 03:37 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Whirlpool RBD305PDQ11 ELECTRIC OVEN | AppliancePartsPros.com
First check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next check the thermal fuse (upper left in the wiring diagram).
This kills power to the transformer (Item 5 in Section 5 of the parts).
I cannot find it in the parts so you will have to call AppliancePartsPros.
Often they look like the following and are in the harness close to the control board or by the transformer.
Part number: AP3110028
Click on the picture for more info.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Appears to have no power. rrab449@yahoo.com Dishwasher Repair 1 02-17-2012 04:33 PM
Lost power Jenn Air dual feul double oven - power won't return my jenn air Oven Repair (including Ranges and Cooktops) 1 11-08-2011 05:46 AM
My oven element broke and now there appears to be no power to any part of the oven Terry37 Oven Repair (including Ranges and Cooktops) 1 06-18-2010 02:39 AM
appears to be no power jtroutking1 Refrigerator & Freezer Repair 0 02-23-2009 01:23 PM
Thermador Double Oven - No Power slkc Oven Repair (including Ranges and Cooktops) 0 06-05-2008 07:56 AM
