Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Intermittent oven/clock problems (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499154-intermittent-oven-clock-problems.html)
Janetjjross 09-05-2012 10:26 AM
My oven/stove has recently started turning off. When this problem first occurred, I was using the oven and some time after starting to bake, noticed that the clock was flashing and the oven was turned off. It took several minutes before I was able to reset the clock. The screen went blank and came back up blinking again. I was able to reset. This started happening more frequently as I used the oven. Then I noticed that without the stove in use, I would see that the clock would just start blinking and I would have to reset it. There were no power problems in the house-nothing else was blinking (microwave, etc). Don't seem to have any problems with the cook top. I have an oven that I can't use, as I cannot depend that it will stay working without interruption. Any ideas??
Thanks so much!
arn 03-19-2015 10:48 AM
Quote:
Thanks so much!
I have a similar problem with a Frigidaire Model CFES388CCS-3 electric range 10+ years old which we have had since new. It seems to be temperature related - stays on longer between having to reset at lower oven temperatures i.e. with oven set at 350 it stays on longer than at a 400 setting. I think its a clock problem but of course Frigidaire doesn't stock any parts like the clock anymore for this model and has no idea of a similar part that would work. Nothing else wrong with the range but have to buy new due to lack of a $100 part
