| » One burner will not spark or "tick" |
Model Number: JGP337WEJ3WW Brand: GE Age: 5 - 10 years
Hi!
Hope you can help me. The left rear burner does not spark or "tick" when I turn it on. I also replaced the igniter with no luck. Gas is flowing. It will ignite with a lighter. It does not "tick" when the other burners are turned on. I need to know which part I need to order to fix the problem. Can you please help? Ads By Google Related Models |
Hi.
Switch around HV igniters wires and check if that makes any difference. You may need to replace the HV wire or the spark module. The module Part number: WB13K25 The wires Part number: WB13K10015 Here are the breakdown diagrams and Replacement parts for General Electric JGP337WEJ3WW Gas range | AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks for the quick reply. I'll try switching the HV igniters to see if the "dead" burner ticks. I wasn't sure if I should replace the module or the individual valve. I'll let you know what happens.
Don't switch the ignitors, only the wires.
Simon.
__________________
Quote:
I was unable to switch the HV igniter wires since they are custom-cut to the length to reach each burner. I am ordering a wire harness, since it appears the switch for the left rear burner won't "click." Gas flows, but no ignition. I'm hoping replacing the switch wire assembly will solve the problem |
Hi.
Try to switch the wires at the spark module. Simon.
__________________
| Display Modes | |
| Bosch dryer stops, beeps, "Drying" and "End" lights on | endyem | Dryer Repair | 2 | 10-19-2012 04:46 PM |
| Igniter continues to spark w/ knob in "Off" | Steve Y | Oven Repair (including Ranges and Cooktops) | 0 | 11-24-2011 06:41 AM |
| Neptune MD5500 Washer:Error Codes "do" and "FL" with a triple beep and a buzzer sound | neptune123 | Washer Repair | 1 | 06-12-2011 04:14 PM |
| oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open | samej71 | Oven Repair (including Ranges and Cooktops) | 2 | 03-24-2010 07:05 AM |
| Top burners no longer "spark" & don't lite | William Lidyard | Oven Repair (including Ranges and Cooktops) | 1 | 09-04-2008 10:20 AM |
