Discuss
Maytag CRE8600CCE electric stove control panel blank
 in
Hello, Hope you can help me. I have a Maytag CRE8600CCE electric stove/oven. Electric power had been shut off, and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag CRE8600CCE electric stove control panel blank
  #1 (permalink)
Old 09-22-2009, 04:45 PM
Junior Member
ropat is on a distinguished road
Red face Maytag CRE8600CCE electric stove control panel blank
Model Number: CRE8600CCE   Brand: Maytag   Age: 5 - 10 years
Hello,
Electric power had been shut off, and when the power turned back on the control panel is blank totally black.
I have checked and flipped all the breaker switches to on and off back on again, and unplugged the 240v stove cord. Tried hold the cancel button for awhile and still blank.
All 4 electric burners on top work and the light comes on in the oven.
Are there any small transformers that may have blown out when the electric was powered off?
Please may I get the tech sheet or service manual for this Maytag CRE8600CCE stove?
Have read all your stickys about the ohm meter so that will be the next in line that I do. I have an analog meter and will be using it.
It's cold here in Colorado right now and I sure would like to bake a hot meal tonight.
Related Models
Maytag CRE8600CCE RANGE- S/C F/S ELE
Maytag CRE8600CCL RANGE- S/C F/S ELE
Maytag CRE8600CCM RANGE- S/C F/S ELE
Maytag CRE8600CCW RANGE- S/C F/S ELE
Maytag CRE8700ADE RANGE- S/C F/S ELE
Maytag CRE8700ADL RANGE- S/C F/S ELE
Maytag CRE8700ADW RANGE- S/C F/S ELE
Maytag CRE8700BDE RANGE- S/C F/S ELE
Maytag CRE8700BDL RANGE- S/C F/S ELE
Maytag CRE8700BDW RANGE- S/C F/S ELE
Maytag CRE8700CDE RANGE- S/C F/S ELE
Maytag CRE8700CDL RANGE- S/C F/S ELE
Maytag CRE8700CDW RANGE- S/C F/S ELE
Maytag CRE8700DDE RANGE- S/C F/S ELE
Maytag CRE8700DDM RANGE- S/C F/S ELE
Maytag CRE883 RANGE- S/C F/S ELE
Maytag CRE900 RANGE- S/C F/S ELE
Maytag CRE9300BCW RANGE- S/C F/S ELE
Maytag CRE9300CCL RANGE- S/C F/S ELE
Maytag CRE9300CCW RANGE- S/C F/S ELE
Maytag CRE9400ACE RANGE- S/C F/S ELE
Maytag CRE9400ACL RANGE- S/C F/S ELE
Maytag CRE9400ACW RANGE- S/C F/S ELE
Maytag CRE9400BCE RANGE- S/C F/S ELE
Maytag CRE9400BCL RANGE- S/C F/S ELE
Maytag CRE9400BCM RANGE- S/C F/S ELE
Maytag CRE9400BCW RANGE- S/C F/S ELE
Maytag CRE9400CCB RANGE- S/C F/S ELE
Maytag CRE9400CCE RANGE- S/C F/S ELE
Maytag CRE9400CCL RANGE- S/C F/S ELE
Maytag CRE9400CCM RANGE- S/C F/S ELE
Maytag CRE9400CCW RANGE- S/C F/S ELE
Maytag CRE9500ACE RANGE- S/C F/S ELE
Maytag CRE9500ACL RANGE- S/C F/S ELE
Maytag CRE9500ACW RANGE- S/C F/S ELE
Maytag CRE9500ADE RANGE- S/C F/S ELE
Maytag CRE9500ADL RANGE- S/C F/S ELE
Maytag CRE9500ADW RANGE- S/C F/S ELE
Maytag CRE9500BCE RANGE- S/C F/S ELE
Maytag CRE9500BCL RANGE- S/C F/S ELE
Maytag CRE9500BCW RANGE- S/C F/S ELE
Maytag CRE9500BDE RANGE- S/C F/S ELE
Maytag CRE9500BDL RANGE- S/C F/S ELE
Maytag CRE9500BDW RANGE- S/C F/S ELE
Maytag CRE9500CCE RANGE- S/C F/S ELE
Maytag CRE9500CCM RANGE- S/C F/S ELE
Maytag CRE9500CDE RANGE- S/C F/S ELE
Maytag CRE9500CDL RANGE- S/C F/S ELE
Maytag CRE9500CDW RANGE- S/C F/S ELE
Maytag CRE9500DDE RANGE- S/C F/S ELE
Maytag CRE9500DDM RANGE- S/C F/S ELE
Maytag CRE9530BCE RANGE- S/C F/S ELE
Maytag CRE9530BCM RANGE- S/C F/S ELE
Maytag CRE9530CDE RANGE- S/C F/S ELE
Maytag CRE9530CDM RANGE- S/C F/S ELE
Maytag CRE955 RANGE- S/C F/S ELE
Maytag CRE9590CCL RANGE- S/C F/S ELE
Maytag CRE9590CCW RANGE- S/C F/S ELE
Maytag CRE9600ACE RANGE- S/C F/S ELE
Maytag CRE9600ACL RANGE- S/C F/S ELE
Maytag CRE9600ACW RANGE- S/C F/S ELE
Maytag CRE9600ADE RANGE- S/C F/S ELE
Maytag CRE9600ADL RANGE- S/C F/S ELE
Maytag CRE9600ADW RANGE- S/C F/S ELE
Maytag CRE9600BCE RANGE- S/C F/S ELE
Maytag CRE9600BCL RANGE- S/C F/S ELE
Maytag CRE9600BCW RANGE- S/C F/S ELE
Maytag CRE9600CCE RANGE- S/C F/S ELE
Maytag CRE9600CCM RANGE- S/C F/S ELE
Maytag CRE9600CDE RANGE- S/C F/S ELE
Maytag CRE9600CDL RANGE- S/C F/S ELE
Maytag CRE9600CDW RANGE- S/C F/S ELE
Admiral CRE9600CGE RANGE- S/C F/S ELE
Maytag CRE9600DDE RANGE- S/C F/S ELE
Maytag CRE9600DDM RANGE- S/C F/S ELE
Maytag CRE9700ACB RANGE- S/C F/S ELE
Maytag CRE9700ACE RANGE- S/C F/S ELE
Maytag CRE9700ADB RANGE- S/C F/S ELE
Maytag CRE9700ADE RANGE- S/C F/S ELE
Maytag CRE9800ACB RANGE- S/C F/S ELE
Maytag CRE9800ACE RANGE- S/C F/S ELE
Maytag CRE9800ADB RANGE- S/C F/S ELE
Maytag CRE9800ADE RANGE- S/C F/S ELE
Maytag CRE9800BCB RANGE- S/C F/S ELE
Maytag CRE9800BCE RANGE- S/C F/S ELE
Maytag CRE9800CCB RANGE- S/C F/S ELE
Maytag CRE9800CCE RANGE- S/C F/S ELE
Maytag CRE9800CCM RANGE- S/C F/S ELE
Maytag CRE9800CDB RANGE- S/C F/S ELE
Maytag CRE9800CDE RANGE- S/C F/S ELE
Maytag CRE9800DDB RANGE- S/C F/S ELE
Maytag CRE9800DDE RANGE- S/C F/S ELE
Maytag CRE9800DDM RANGE- S/C F/S ELE
Maytag CRE9830BCB RANGE- S/C F/S ELE
Maytag CRE9830BCE RANGE- S/C F/S ELE
Maytag CRE9830BCM RANGE- S/C F/S ELE
Maytag CRE9830CDB RANGE- S/C F/S ELE
Maytag CRE9830CDE RANGE- S/C F/S ELE
Maytag CRE9830CDM RANGE- S/C F/S ELE
Maytag CRE9900ACB RANGE- S/C F/S ELE
Maytag CRE9900ACE RANGE- S/C F/S ELE
Admiral CREA200ACL RANGE- F/S STD ELE
Admiral CREA200ACW RANGE- F/S STD ELE
Admiral CREA300ACL RANGE- F/S STD ELE
Admiral CREA300ACW RANGE- F/S STD ELE
Admiral CREA400ACL RANGE- F/S STD ELE
Admiral CREA400ACW RANGE- F/S STD ELE
Admiral CREA450ACL RANGE- F/S STD ELE
Admiral CREA450ACW RANGE- F/S STD ELE
Admiral CREA600ACE RANGE- S/C F/S ELE
Admiral CREA600ACL RANGE- S/C F/S ELE
Admiral CREA600ACW RANGE- S/C F/S ELE
Admiral CREA650ACB RANGE- S/C F/S ELE
Admiral CREA650ACL RANGE- S/C F/S ELE
Admiral CREA650ACW RANGE- S/C F/S ELE
Admiral CREA750ACB RANGE- S/C F/S ELE
Admiral CREA750ACE RANGE- S/C F/S ELE
Admiral CREA750ACM RANGE- S/C F/S ELE
Frigidaire CREF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CREF342AS1 Dryer - Frig/best Buy
  #2 (permalink)
Old 09-23-2009, 07:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the control board (aka a clock) has gone bad. The low voltage transformer is a part of the clock. In order to prevent such situation I would recommend to install a surge protector. It can be a good idea to call a certified electrician to estimate a whole house surge protector installation.
- The clock Part number: AP4008548
Here are the breakdown diagrams and Replacement parts for MAYTAG CRE8600CCE | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blank control panel legodad1@yahoo.com Dishwasher Repair 1 02-03-2010 02:17 AM
control panel blank martitek Microwave Repair 0 06-27-2009 10:54 PM
Control panel blank 1957pickup Dishwasher Repair 1 09-08-2008 09:02 PM
Control Panel went blank TonyRoy Oven Repair (including Ranges and Cooktops) 3 01-28-2008 12:12 PM
Maytag Electric Range Control Panel Dim Chryslerpetz Oven Repair (including Ranges and Cooktops) 0 12-26-2007 06:52 PM
