cmb
#1 Posted : Tuesday, September 22, 2009 12:48:00 PM(UTC)
cmb
When you put the oven on Bake it will not heat over 200 degrees. Before when you go to bake it would automatically show 350 Degrees. But doesnt do that anymore at all.The element works fine on broil.
#2 Posted : Wednesday, September 23, 2009 12:30:23 PM(UTC)
Remove the oven floor and inspect the Bake heating element.
If there is no visible damages then pull the range out of the wall, remove the rear panel and inspect the wires to the heating element.
Remove the wires from the heating element and check the element for continuity.
Check for 240 VAC between the heating element wires while the control calls for Bake.
Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG PER5750LAW | AppliancePartsPros.com
cmb
#3 Posted : Thursday, September 24, 2009 6:29:06 PM(UTC)
cmb
Yes thank you the element is bad
#4 Posted : Thursday, September 24, 2009 9:55:25 PM(UTC)
The Bake element Part number: AP4101290
cmb
#5 Posted : Friday, September 25, 2009 3:24:25 AM(UTC)
cmb
Thank you gene for your help, I am going to try and pick one up local at ************** appliance in tampa. If i need to order i will have you order it for me.
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
oven cycle light comes on and goes off when oven is not on (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2024 7:45:28 AM(UTC)
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
Samsung oven temp low limit not switching back on (Oven Repair (including Ranges and Cooktops))
by amriths 2/25/2024 9:26:15 AM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
Viking propane range #VGCC530-4B, oven/broiler dead, all other features working (Oven Repair (including Ranges and Cooktops))
by Andy Douglass 2/21/2024 2:06:07 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Whirlpool Oven WFE770H0FZ2 (Oven Repair (including Ranges and Cooktops))
by Guest 2/9/2024 7:03:09 AM(UTC)
power outage has my oven unable to turn on to reset (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 10:17:47 PM(UTC)
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
