| » Whirlpool Oven/Stovetop Electric |
A model number would be helpful.
Model Number Locator You may have a problem with the 240 volts going to the unit. It is required to heat all the elements on the unit. The lights, control/clock all run of of half the line (120 volts) Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!!
__________________
| Display Modes | |
| Frigidaire Electric stovetop (flat top) burner stopped working | Bethany257 | Oven Repair (including Ranges and Cooktops) | 0 | 10-25-2010 03:26 PM |
| Electric Stovetop Cleaning | shawnsiegel | Oven Repair (including Ranges and Cooktops) | 2 | 04-16-2010 08:09 PM |
| Whirlpool oven not work,stovetop works fine | ARTI | Oven Repair (including Ranges and Cooktops) | 1 | 10-11-2009 07:51 AM |
| Whirlpool stovetop works..oven dont..no gas? | trishaandtim | Oven Repair (including Ranges and Cooktops) | 2 | 06-23-2009 12:46 PM |
| Need to replace wiring harness on electric stovetop | blarzelere | Oven Repair (including Ranges and Cooktops) | 0 | 05-30-2009 08:42 PM |
