| » One gas burner won't stay lit on low |
Model Number: JGB928 Brand: GE Age: 1 - 5 years
I just bought this house and the GE JGB928 gas range works great except one burner, left front, runs fine until I turn it to low and it goes out. This is my first gas stove, but I have been handy on all types of other appliances. Is there someting that may be clogged. The book states it is a sealed burner unit.
Hi.
Remove the burner cap and burner had. Locate the burner orifice inside the opening and clean it using the needle or wire. If that doesn't help - replace the burner valve #15 l/f on diagram. Here are the breakdown diagrams and Gas & Burner parts for GE JGB928BEK1BB - AppliancePartsPros.com Post the results. Simon. P.S. Check if the actual model number is the same as the one on the diagram.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 11-30-2012 at 04:30 PM. |
Simon,
Thanks for the reply. I got the burner to work using a small wire. I did the same for all of my other burners just in case. I have a minor problem with my left front burner, it sometimes goes lower on #2 than on low, and occasionally goes out. I have model JGB928SEL1SS and it shows three valve burners WB21K10044 through 46 and a Hi Cap. (out of stock). If I decide to replace this gas burner, which one is the left front (Large Head). Also, how do I get to the valve burner? There are two screws that appear to hold down the burner base but it also seems to be held down by the ignitor. Do these bases need to be removed or does the Cook top just lift up? Once I get to the valve burner is it a simple swap out? Thanks, Ken |
Hi.
Is it small, medium or large burner? To replace it remove all 4 burners by taking out 2 screws from each burner base and pulling it up.Then lift the top.The valve is held by one 1/4 or 5/16 screw. Don't forget to turn the power and gas off. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 12-03-2012 at 11:48 AM. |
According to the manual it is the large burner, left front. Not the Extra Large, right front.
I tried to remove this burner base by removing the two screws, but the igniter seems to try to hold the burner base down, like it all is one unit. How do I release the igniter and what about the wire(s) to the igniter? If I have to order the burner valve, how long would it take to get the correct one in stock? Thanks, Ken |
Hi.
Here is your valve Part number: WB21K10045 Please contact our customer service for the delivery date. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Simon,
Thanks for the help and info. I still have one question: when I take out the two screws, the igniter still seems to hold the burner base down. What do I need to do to get the burner base to release, or do I need to? The burner parts are listed as WB...44 at 5000, WB... 45 at 9500 and WB...46 at 13000 plus a high capacity which I do not know the BTU's. Is the 44 right rear, 45 left rear, 46 left front (my problem burner? Or do I have these wrong? Thanks, Ken Last edited by knwollen : 12-04-2012 at 05:09 PM. |
Hi.
You are right the 13000btu is the one you need.Sorry I was misled by 1300 number (one zero is missing). The burner valve p/n WB21K10046. Use the putty knife to ease off the base. Simon.
__________________
| Display Modes | |
| Burner will not stay lit | rlsundman | Dryer Repair | 5 | 03-17-2012 03:37 PM |
| Dual burner won't stay on | gmwolfson | Oven Repair (including Ranges and Cooktops) | 0 | 09-13-2011 01:02 PM |
| Oven burner does not stay lit | larryo58 | Oven Repair (including Ranges and Cooktops) | 0 | 07-23-2011 01:16 PM |
| burner won't stay on | kurtboyd | Dryer Repair | 1 | 10-24-2010 04:32 PM |
| Burner will not stay lit | samo1029 | Dryer Repair | 0 | 01-10-2010 11:48 AM |
