Discuss
One gas burner won't stay lit on low
 in
Simon, I have removed all of the screws to the Burner Bases on the Cook Top and none of them
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » One gas burner won't stay lit on low
  #11 (permalink)
Old 12-05-2012, 02:15 PM
Junior Member
knwollen is on a distinguished road
Default
Simon,
I have removed all of the screws to the Burner Bases on the Cook Top and none of them will lift out because the #13 burner electrode appears to be held from under the cook top with the #168 Clip Electrode. All the Bases wiggle, but the electrode keeps them fastened down. I can't see any way to get the electrodes loose from above.
Will the cook top, along with the lossened Burner Bases and electrodes just pop up if I pry along the front of the cook top and try to lift it up and how much force should I apply? Or is something else need to be disconnected in order to get the cook top open.
Once I can get the Cook top off, It looks like a simple swap out. Oh yeah, if I ever have to replace a electrode it appears I need to get to them from under the Cook Top also.
New: I tried to gently pry - no good. The electrodes don't budge. Do I need to remove the front panel and what is the procedure for that? It looks like 4 screws but what about the controls.
I know I am guessing a lot. Basically how do I get the cook top raised in order to repair anything under it?
Thanks,
Ken
  #12 (permalink)
Old 12-06-2012, 04:41 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Use the putty knife to open the two clips holding the top (one on each side above the control panel).
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 12-07-2012, 08:19 AM
Junior Member
Default
Simon,
Thanks for the information. I will give it a try next week, to much going on the next few days.
Ken
  #14 (permalink)
Old 12-07-2012, 11:54 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner does not stay lit larryo58 Oven Repair (including Ranges and Cooktops) 1 06-29-2015 06:06 PM
Burner will not stay lit rlsundman Dryer Repair 5 03-17-2012 04:37 PM
Dual burner won't stay on gmwolfson Oven Repair (including Ranges and Cooktops) 0 09-13-2011 02:02 PM
burner won't stay on kurtboyd Dryer Repair 1 10-24-2010 05:32 PM
Burner will not stay lit samo1029 Dryer Repair 0 01-10-2010 12:48 PM
