Hello,
My oven is not working. Will not light or heat up. The broiler and range are operating fine. This is all powered by propane gas.
This happened several months ago and I reset the circuit breaker and it fixed the problem. That didn't work this time however.
Any help would be appreciated. Thank you.
-Jennifer
Jennifer,
The model number you posted does not come up. Verify and repost it.
OOops! That is....JGBP28WEA4WW
Most likely the problem is a bad Bake igniter (#28 on the diagram). Remove the bottom drawer, disconnect the igniter wires and check it for continuity. - The igniter Part number: AP2014008
