Loopy
#1 Posted : Thursday, August 30, 2012 10:24:46 AM(UTC)
Loopy
I have had to change the front right custom control element twice on this unit. The elements test OK it the temp probe/thermocouple that fails. The part only comes as a complete unit with the element.
Is it possible to find a similar thermocouple that I can adapt to the element?
Has anyone tried this?
#2 Posted : Thursday, August 30, 2012 3:17:31 PM(UTC)
I don't think it is possible because the manufacturer does not sell it separate.
Loopy
#3 Posted : Friday, August 31, 2012 7:13:33 PM(UTC)
Loopy
If I could find out what the temp. range on the RTD is, I could find one that can be adapted.
Jenn Air Range spark module keeps sparking with switch turned off (Oven Repair (including Ranges and Cooktops))
by Guest 2/16/2022 11:48:26 AM(UTC)
Jenn Air Range (Oven Repair (including Ranges and Cooktops))
by DonTaylor 9/24/2017 6:13:49 AM(UTC)
Jenn Air Range Burner HOT (Oven Repair (including Ranges and Cooktops))
by agdodge4x4 1/19/2016 4:48:15 PM(UTC)
Jenn Air Range/Convection oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by Pamwest 11/30/2015 11:09:20 AM(UTC)
keypad Jenn Air Range (Oven Repair (including Ranges and Cooktops))
by Teacher Jim 6/18/2015 9:44:08 AM(UTC)
Jenn Air Range Cooktop Hot Indicator Stays On For Hours (Oven Repair (including Ranges and Cooktops))
by beachbreeze 4/1/2013 8:47:30 AM(UTC)
by Loopy 8/30/2012 8:45:42 AM(UTC)
FC error code on Jenn Air range (Oven Repair (including Ranges and Cooktops))
by jayjohn 6/20/2012 8:16:41 AM(UTC)
Replace burner control of Jenn Air range (Oven Repair (including Ranges and Cooktops))
by guy39 10/5/2009 5:15:46 AM(UTC)
FC Error on Jenn Air range (Oven Repair (including Ranges and Cooktops))
by prichardh 5/11/2009 10:00:38 AM(UTC)
Jenn air range glass cooktop replacement (Oven Repair (including Ranges and Cooktops))
by santostefano 4/21/2009 2:10:56 PM(UTC)
Older Jenn Air Range Fan Switch Replace--How To?? (Oven Repair (including Ranges and Cooktops))
by ibjessa 4/3/2009 12:10:14 AM(UTC)
jenn air range (Oven Repair (including Ranges and Cooktops))
by kkillian 3/14/2009 9:34:56 AM(UTC)
by ed wilson 10/2/2008 6:49:05 AM(UTC)
Jenn Air range error code F1-8 when hot (Oven Repair (including Ranges and Cooktops))
by JimSimpson 9/24/2008 6:19:30 PM(UTC)
