Discuss
F4 error message
 in
Replaced bake element which led to F4 error. Replaced temp sensor but still F4. Any thoughts?
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F4 error message
  #1 (permalink)
Old 01-29-2008, 05:18 PM
GG49 GG49 is offline
Junior Member
GG49 is on a distinguished road
Default F4 error message
Model Number: B59Fn-5TVW   Brand: Magic Chef   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-29-2008, 09:11 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The "F4" error code means the control board senses the oven temperature sensor is shorted.
The first thing I would do is check for continuity the oven sensor at the control board. The normal oven sensor resistance at the room temperature suppose to be about 1100 Ohms.
If the reading is correct - replace the control board.
If the reading is wrong then measure the oven sensor resistance at the sensor plug.
If the reading is wrong - replace the oven sensor.
If the readings correct then the problem is the wire harness.
- The part number for the control board is AP382905
- The part number for the oven temperature sensor is AP204836
- The part number for the oven sensor harness is AP308592
Here are the break down diagrams for the Magic Chef range Model B59FN-5TVW
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"Err" message when trying to Bake above 260 pmueller07 Oven Repair (including Ranges and Cooktops) 6 03-22-2008 07:11 PM
F 20 Error message Nell Oven Repair (including Ranges and Cooktops) 1 11-29-2007 02:15 PM
Faulty spray arm blockage message Dave Northrop Dishwasher Repair 5 10-02-2007 11:41 PM
p/f message---cycle stops snuffydog Dishwasher Repair 1 09-19-2007 10:30 PM
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
