| » Jenn-Air - Maytag W181 wide temp range |
Model Number: W181 Brand: Jenn-Air Age: More than 10 years
The oven works, per se. But, the temp swings between the elements turning off and on are about 56degF on Bake Convection using a household digital oven thermometer. Is this kind of range normal?
This oven has a sophisticated (for its day) electronic control panel and I wonder if the range can be controlled/adjusted by that electronic board. Ads By Google Related Models |
Hi.
Does the cooking takes way too long or it's normal? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
My daughter graduated a baking /pastry program and she has been having problems with temperature inconsistencies. I guess a tri-tip is very forgiving of a wide temp range but cookies and stuff, are not.
Can the control board tighten up that range? I know that has calibrations for the thermostat so I thought that maybe it could do that, too. |
I do not believe that the range can be changed.
Simon.
__________________
Hi.
The detailed schematic of the control board is never available. Simon.
__________________
You are welcome.
Simon.
__________________
Simon,
Two questions regarding normal brands of residential wall ovens (not incl Viking, Wolf, etc): 1. Are there any brands of normal residential wall ovens that have the capacity to adjust that OR actually state that info as part of their specifications?? 2. Is a +/- 30degF cooking cycle variation normal/typical? Thanks again, Lar |
Hi.
1. As far as I've heard the differential is a build in feature (some old thermostat operated ovens had this adjustment possible). 2.The 30*F is a max temperature adjustment. Simon.
__________________
| Display Modes | |
| Refrigerator Temp too wide of spread | jlb27537 | Refrigerator & Freezer Repair | 0 | 04-22-2011 04:39 AM |
| Maytag Gas Range Temp | janhuggies | Oven Repair (including Ranges and Cooktops) | 7 | 01-23-2011 03:00 PM |
| Refrigerator freezer - wide temp swings | Wehrme | Refrigerator & Freezer Repair | 1 | 10-01-2009 05:07 AM |
| Jenn-Air W181 Wall Oven Door Disassembly | Larbo | Oven Repair (including Ranges and Cooktops) | 0 | 08-21-2009 07:25 AM |
