Oven nor burners will come on. When turning on burner the indicator lights up, but burner doesn't heat up. Clock stays off but flashes when burner is turned on along with PF. Have replaced timer clock with a new. Old one did the same.
Groups: APP Team
Hi.
Check if there is 240VAC to the range. Reset the circuit breaker.
Post the results.
Simon.
Yes 240 is getting to the unit. I placed meter on l1 & L2 to neutral. Breakers were reset. Problem not resolved.
Groups: APP Team
Hi.
Does the clock work OK? Will the oven work without the burners on? Does all the burners acting the same?
Simon.
Originally Posted by: Simon / APP Team Hi.
Does the clock work OK? No Turns off when the burner knob is turned off Will the oven work without the burners on? No Does all the burners acting the same? YEs. Not Working.
Simon. I did find the problem or perhaps the start of the problem. Where the wiring harness attaches to the back of the oven/unit. From L1, L2 and Neutral the post on the far right is charred and loose. Wish I could send a picture. I did take one.
Groups: APP Team
Hi.
This is definitely the cause of the problem. Put new connectors and hopefully that will be it.
Simon.
