Discuss
gas oven not heating up like it should
 in
We have replaced the gas safety valve and the oven still does not heat up like it should. I had
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » gas oven not heating up like it should
  #1 (permalink)
Old 01-29-2008, 11:47 AM
fillhardfarm fillhardfarm is offline
Junior Member
fillhardfarm is on a distinguished road
Default gas oven not heating up like it should
Model Number: TGF355BHWB   Brand: Tappan   Age: 5 - 10 years
We have replaced the gas safety valve and the oven still does not heat up like it should. I had gotten no response to my original post so I am reposting. Any help would be greatly appreciated as I would really like to have a working oven back but I really don't want to have to buy a new stove.
Thanks!
Christi
ORIGINAL POST
My oven won't heat to temperature correctly. I think I know what we need but want another opinion before I order the part.
We had a friend look at it that used to do appliance repair and he said that we need the gas safety valve.
It heats up but you have to set it to about 425 to get it to 350. Right now I have it a 470 for it to get to 425. Then it doesn't always stay at that temperature so you have to watch it.
He came and looked at it, took the bottom of the oven out and shook that valve around and then put it back together. This was a year ago and it worked since then until a few weeks ago and now it is doing it again.
Do you think that is it and that safety valve is just full of crud or something?
I want to order the part and get it fixed because baking is really a pain right now with it the way it is.
Thanks for any advise
Christi
fillhardfarm@sbcglobal.net
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-29-2008, 07:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Christi,
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) wires at the control board.
It suppose to be about 1100 Ohms at the room temperature.
If the readings is different - replace the oven temperature probe.
If there is nothing wrong then replace the control board (aka clock).
Also if it takes more than a minute to light up the burner (on cold oven) - very possible the oven igniter has to be replaced too.
- The part number for the oven temperature probe is AP2126179
- The part number for the control board is AP2125563
- The part number for the oven igniter is AP2150412
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Wall Double Oven Top Oven Not Heating ryoung Oven Repair (including Ranges and Cooktops) 0 01-10-2008 09:02 PM
Oven not heating feinerl Oven Repair (including Ranges and Cooktops) 2 12-22-2007 02:01 PM
Gas Oven Not Heating defirechief8915 Oven Repair (including Ranges and Cooktops) 3 10-24-2007 09:26 PM
Oven keeps heating rowilson Oven Repair (including Ranges and Cooktops) 5 10-16-2007 07:05 PM
oven not heating ljticeman Oven Repair (including Ranges and Cooktops) 1 08-01-2007 04:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
