richwest41
#1 Posted : Wednesday, August 22, 2012 4:10:05 PM(UTC)
richwest41
Sometime when cooking the oven randomly will shut off. Usually after 15 minutes or more. The display panel remains on but the cooking mode shuts down. This happens most frequently when we open the oven to check on the item cooking than close the door.
Would appreciate any ides.
Simon / APP Team
#2 Posted : Wednesday, August 22, 2012 5:24:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is with the display board.
Here are the breakdown diagrams and Replacement parts for Thermador C271U BUILT-IN OVENS | AppliancePartsPros.com
Simon.
PS. You can always return the part even if it's been installed.
richwest41
#3 Posted : Monday, September 10, 2012 5:14:58 PM(UTC)
richwest41
I replaced part number AP3851310 which I believe is the display but seems to also be referred to as a control board, about a year and a half ago. Is this the part you suggest I replace. Also do they normally go bad this often? Thanks for your help
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
#4 Posted : Tuesday, September 11, 2012 12:40:17 PM(UTC)
Originally Posted by: richwest41 Go to Quoted Post
...I replaced part number AP3851310 which I believe is the display but seems to also be referred to as a control board, about a year and a half ago...
What was the problem at that time?
Sounds like this part failed again.
Quote:
...Also do they normally go bad this often?...
Normally any part should last much longer but...
richwest41
#5 Posted : Tuesday, September 11, 2012 5:01:57 PM(UTC)
richwest41
The last time I had problems the oven would beep and the unit would stop cooking. We would have to shut it down at the circuit box and reset it numerous times to get it to go back on again. Also, on some occasions we would get an F-24 error code.
#6 Posted : Tuesday, September 11, 2012 6:06:13 PM(UTC)
It looks to me like the same part failure.
Whirlpool oven shuts off overnight (Oven Repair (including Ranges and Cooktops))
by Guest 4/15/2021 3:53:14 PM(UTC)
Oven shuts off by itslf (Oven Repair (including Ranges and Cooktops))
by kdsagun 4/15/2018 5:55:28 PM(UTC)
Oven shuts off after heating up (Oven Repair (including Ranges and Cooktops))
by ravellar 4/24/2017 12:10:21 PM(UTC)
Whirlpool oven shuts off baking/broiling (Oven Repair (including Ranges and Cooktops))
by bremen242 2/13/2017 4:12:13 PM(UTC)
Whirlpool Gold oven shuts off when temp changed (Oven Repair (including Ranges and Cooktops))
by texicus 9/24/2015 9:30:38 AM(UTC)
Panasonic oven shuts off NN-SA651S (Microwave Repair)
by ladybridgeport 4/23/2014 10:49:07 AM(UTC)
Oven shuts off by itself (Oven Repair (including Ranges and Cooktops))
by bobtam 5/16/2013 3:40:22 PM(UTC)
oven shuts off after 45 min (Oven Repair (including Ranges and Cooktops))
by Karl Lauther 4/22/2013 2:49:55 PM(UTC)
kenmore ultra bake oven shuts off (Oven Repair (including Ranges and Cooktops))
by urbanrover 3/13/2013 12:47:40 PM(UTC)
Oven shuts off while cooking, sometimes trouble starting (Oven Repair (including Ranges and Cooktops))
by mrs9693nj 2/15/2013 1:31:41 PM(UTC)
JENN-AIR oven shuts off after a few minutes of heating (Oven Repair (including Ranges and Cooktops))
by toolrules 2/10/2013 7:45:46 PM(UTC)
After pre heat oven shuts off (Oven Repair (including Ranges and Cooktops))
by rider136 9/24/2012 3:37:31 PM(UTC)
Jenn-air oven shuts off (Oven Repair (including Ranges and Cooktops))
by Wardenmotorsports 9/18/2012 4:21:59 PM(UTC)
Oven shuts off within ten minutes (Oven Repair (including Ranges and Cooktops))
by TMeck 8/22/2012 2:00:23 PM(UTC)
Oven Shuts off (Oven Repair (including Ranges and Cooktops))
by chilidog 5/13/2012 5:45:59 PM(UTC)
