| » Jenn Air upper broiler not working |
Model Number: ww27430b Brand: Jenn-Air Age: More than 10 years
The upper oven broiler element will not heat up. The setting works fine, fan comes on but the element does not heat. I exchanged it with the one in the lower oven and the element is not the problem. Any suggestions on what to investigate next?
If the Bake element works but the Broil does not then, most likely, the problem is a bad main relay board on the right side in the control compartment.
- The relay board Part number: 74006612 Here are the breakdown diagrams and Replacement parts for Jenn-Air WW27430B WALLOVEN- S/C ELE | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Quote:
Quote:
__________________
Quote:
__________________
Quote:
Finally getting around to ordering the replace the circuit board you recommended. Would it be prudent to order a thermostat at the same time considering I will have the oven out of the wall? Thanks Frank |
Frank,
Which thermostat did you mean? Why this part become questionable? Gene.
__________________
I am just thinking an older oven, older thermostat denegrating with time; when I am pulling out the unit to replace the board would it be best pratices to simply replace the thermostat on the upper oven. Perhaps I am being slightly anal.
Thanks for your input |
I don't think you have to do it at this time.
__________________
| Display Modes | |
| Jenn-air oven/broiler no longer working - have details! | Synon | Oven Repair (including Ranges and Cooktops) | 1 | 08-08-2012 04:15 AM |
| Jenn-air oven/broiler no longer working - have details! | Synon | Oven Repair (including Ranges and Cooktops) | 0 | 08-07-2012 05:41 PM |
| oven/broiler not lighting upper burners work | gotsweetpea | Oven Repair (including Ranges and Cooktops) | 0 | 01-05-2012 03:26 PM |
| Broiler Upper Oven Element Replacement | Auzzie | Oven Repair (including Ranges and Cooktops) | 3 | 10-04-2010 02:31 PM |
| Jenn-Air Oven and Broiler Elements Not Working | DavidRG | Oven Repair (including Ranges and Cooktops) | 4 | 04-16-2010 09:54 PM |
