Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Jenn Air upper broiler not working (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/495279-jenn-air-upper-broiler-not-working.html)
fgo2 08-14-2012 03:29 PM
The upper oven broiler element will not heat up. The setting works fine, fan comes on but the element does not heat. I exchanged it with the one in the lower oven and the element is not the problem. Any suggestions on what to investigate next?
Gene 08-14-2012 04:28 PM
If the Bake element works but the Broil does not then, most likely, the problem is a bad main relay board on the right side in the control compartment.
- The relay board Part number: 74006612
Here are the breakdown diagrams and Replacement parts for Jenn-Air WW27430B WALLOVEN- S/C ELE | AppliancePartsPros.com
fgo2 08-14-2012 05:30 PM
Gene, Thanks for the prompt response. One more question, is there a method to test this board or is it just a replace and see item?
dmeekins 08-15-2012 12:10 PM
upper oven stays on oll the time
My upper oven (upper burner only) stays on all the time after replacing my lower unit control board. It has never done this before. Suggestions.
Gene 08-15-2012 01:51 PM
Quote:
The only thing which can cause it besides the relay board is a broken wire between the relay board and the heating element.
Gene 08-15-2012 01:53 PM
Quote:
What is the complete model number of the oven and the part number of the new control board?
fgo2 10-08-2012 04:47 AM
Quote:
Gene,
Finally getting around to ordering the replace the circuit board you recommended. Would it be prudent to order a thermostat at the same time considering I will have the oven out of the wall?
Thanks Frank
Gene 10-08-2012 02:44 PM
Frank,
Which thermostat did you mean? Why this part become questionable?
fgo2 10-09-2012 09:08 AM
I am just thinking an older oven, older thermostat denegrating with time; when I am pulling out the unit to replace the board would it be best pratices to simply replace the thermostat on the upper oven. Perhaps I am being slightly anal.
Thanks for your input
Gene 10-09-2012 01:05 PM
I don't think you have to do it at this time.
