Discuss
Replaced Bake element, now no heat from bake or broil
 in
I replaced a bake element that had failed. However I was trying to do it on the cheap and replaced
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replaced Bake element, now no heat from bake or broil
  #1 (permalink)
Old 08-13-2012, 11:28 PM
Junior Member
adambmoose is on a distinguished road
Question Replaced Bake element, now no heat from bake or broil
Brand: Sears   Age: More than 10 years
I replaced a bake element that had failed. However I was trying to do it on the cheap and replaced it with an element that wasn't exactly the same shape, and I had to drill a couple new holes in the oven wall so that the element terminals would fit. They were about an inch wider than the spacing on the original bake element. When I tested the oven there was no heat, and in fact the broil element quit working at that point. Can I salvage this oven? What happened? Thanks
Adam
Ads By Google
  #2 (permalink)
Old 08-14-2012, 03:11 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
A model number may help others help you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Won't bake or broil after element replaced kmall002 Oven Repair (including Ranges and Cooktops) 1 04-13-2012 04:41 AM
Replaced burner element now bake nor broil works. Russell79 Oven Repair (including Ranges and Cooktops) 3 06-09-2010 06:24 AM
Replaced upper broil element, lower bake element. Elements still not working bumdout Oven Repair (including Ranges and Cooktops) 1 11-25-2009 02:49 PM
Replaced bake element, now won't bake/broil mvwa Oven Repair (including Ranges and Cooktops) 0 10-18-2009 12:55 PM
I replaced the broil and bake element yet my stove still doesn't heat naudnice Oven Repair (including Ranges and Cooktops) 2 12-17-2008 05:07 PM
