Discuss
oven not working
 in
oven not working. I replaced the igniter (which was def faulty due to the wire harness having been melted) and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven not working
  #1 (permalink)
Old 08-09-2012, 10:20 AM
Junior Member
kcgfunk is on a distinguished road
Default oven not working
Model Number: fgs365ecd   Brand: Frigidaire   Age: 1 - 5 years
oven not working. I replaced the igniter (which was def faulty due to the wire harness having been melted) and it still doesnt light. The broiler lights and seems to be fine. I pulled the new oven igniter and plugged it into the broilers wiring harness and it lit up, so it seems ok. i tested the voltage at the valve and with the broiler on the valve tests 3.0 volts when i test the oven side of the valve it reads 120.0 v what gives
Ads By Google
Related Models
Frigidaire FGS365ECD Frigidaire/range
Frigidaire FGS365ECE Frigidaire/gas Range
Frigidaire FGS365EQA Frigidaire/gas Range
Frigidaire FGS365EQB Frigidaire/gas Range
Frigidaire FGS365EQC Frigidaire/range
Frigidaire FGS365ESA Frigidaire/gas Range
Frigidaire FGS365ESB Frigidaire/gas Range
Frigidaire FGS365ESC Frigidaire/range
Frigidaire FGS366EBA Frigidaire/gas Range
Frigidaire FGS366EBB Frigidaire/gas Range
Frigidaire FGS366EBC Frigidaire/range
Frigidaire FGS366EBD Frigidaire/gas Range
Frigidaire FGS366ECA Frigidaire/gas Range
Frigidaire FGS366ECB Frigidaire/gas Range
Frigidaire FGS366ECC Frigidaire/gas Range
Frigidaire FGS366ECD Frigidaire/gas Range
Frigidaire FGS366EQA Frigidaire/gas Range
Frigidaire FGS366EQB Frigidaire/gas Range
Frigidaire FGS366EQC Frigidaire/range
Frigidaire FGS366EQD Frigidaire/gas Range
Frigidaire FGS366ESA Frigidaire/gas Range
Frigidaire FGS366ESB Frigidaire/gas Range
Frigidaire FGS366ESC Frigidaire/range
Frigidaire FGS366ESD Frigidaire/gas Range
Frigidaire FGS367DBA Frigidaire/gas Range
Frigidaire FGS367DSA Frigidaire/gas Range
Frigidaire FGS367EBA Frigidaire/gas Range
Frigidaire FGS367ECA Frigidaire/gas Range
Frigidaire FGS367ECB Frigidaire/gas Range
Frigidaire FGS367ECC Frigidaire/range
Frigidaire FGS367ESA Frigidaire/gas Range
Frigidaire FGS367FCA Frigidaire/gas Range
Frigidaire FGS367FCB Frigidaire/gas Range
Frigidaire FGS379DBA Frigidaire/gas Range
Frigidaire FGS379DCA Frigidaire/gas Range
Frigidaire FGS379DQA Frigidaire/gas Range
Frigidaire FGS379DSA Frigidaire/gas Range
Frigidaire FGS379EBA Frigidaire/gas Range
Frigidaire FGS379ECB Frigidaire/gas Range
Frigidaire FGS379ECC Frigidaire/gas Range
Frigidaire FGS379EQA Frigidaire/gas Range
Frigidaire FGS379ESA Frigidaire/gas Range
Whirlpool FGS385BL0
Whirlpool FGS385BL1
Whirlpool FGS385BL2
Whirlpool FGS385BL3
Whirlpool FGS385BL4
Whirlpool FGS385BL5
Whirlpool FGS385BQ1
Whirlpool FGS385BQ2
Whirlpool FGS385BQ3
Whirlpool FGS385BW0
Whirlpool FGS385BW1
Whirlpool FGS385BW2
Whirlpool FGS385BW3
Whirlpool FGS385BW4
Whirlpool FGS385BW5
Whirlpool FGS385VL0
Whirlpool FGS385VL1
Whirlpool FGS385VL2
Whirlpool FGS385VW0
Whirlpool FGS385VW1
Whirlpool FGS385VW2
Whirlpool FGS385YL0
Whirlpool FGS385YL1
Whirlpool FGS385YW0
Whirlpool FGS385YW1
Whirlpool FGS385YW2
Whirlpool FGS387YL0
Whirlpool FGS387YL1
Whirlpool FGS387YL2
Whirlpool FGS387YL3
Whirlpool FGS387YW0
Whirlpool FGS387YW1
Whirlpool FGS387YW2
Whirlpool FGS387YW3
Whirlpool FGS395BL0
Whirlpool FGS395BW0
Whirlpool FGS395VL0
Whirlpool FGS395VL1
Whirlpool FGS395VL2
Whirlpool FGS395VW0
Whirlpool FGS395VW1
Whirlpool FGS395VW2
Whirlpool FGS395YL0
Whirlpool FGS395YL1
Whirlpool FGS395YW0
Whirlpool FGS395YW1
Whirlpool FGS397XW0
Frigidaire FGW240JN0D Kel(v1) / Side By Side Refrigerator
Frigidaire FGW240JN0W Kel(v2) / Side By Side Refrigerator
Frigidaire FGW240JN1D Kel(v3) / Side By Side Refrigerator
Frigidaire FGW240JN1W Kel(v4) / Side By Side Refrigerator
Frigidaire FGX831CS0 Frigidaire/laundry Center
Frigidaire FGX831CS1 Frigidaire/laundry Center
Frigidaire FGX831FS0 Frigidaire/laundry Center
Frigidaire FGX831MCS0 Frigidaire/laundry Center
Frigidaire FGZ831AS0 Lc - Frigidaire
Frigidaire FGZ831AS1 Lc - Frigidaire
Frigidaire FGZ831AS2 Frigidaire/laundry Center
Frigidaire FH05M4DTFB Gib(v1) / Chest Freezer
Frigidaire FH05M4DTFC Gib(v1) / Chest Freezer
Frigidaire FH05M4DVFA Gib(v2) / Chest Freezer
Frigidaire FH05M4DVFB Gib(v3) / Chest Freezer
Frigidaire FH05M4DVFC Gib(v4) / Chest Freezer
Frigidaire FH05M4DXFA Gib(v1) / Chest Freezer
Frigidaire FH05M4DXFB Gib(v1) / Chest Freezer
Frigidaire FH05M4DXFC Gib(v1) / Chest Freezer
Frigidaire FH05M4DXFD Gib(v1) / Chest Freezer
Frigidaire FH05M4WTFA Gib(v1) / Chest Freezer
Frigidaire FH08M4DXFB Gib(v2) / Chest Freezer
Frigidaire FH08M5DTFB Gib(v2) / Chest Freezer
Frigidaire FH08M5DTFC Gib(v1) / Chest Freezer
Frigidaire FH08M5DUFA Gib(v2) / Chest Freezer
Frigidaire FH08M5DVFA Gib(v3) / Chest Freezer
Frigidaire FH08M5DVFB Gib(v4) / Chest Freezer
Frigidaire FH08M5DVFC Gib(v5) / Chest Freezer
Frigidaire FH08M5DXFA Gib(v2) / Chest Freezer
Frigidaire FH08M5DXFC Gib(v2) / Chest Freezer
Frigidaire FH08M5DXFD Gib(v2) / Chest Freezer
  #2 (permalink)
Old 08-09-2012, 11:59 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check the bake gas valve coil for continuity with one wire off.
If it's open - replace it.
if not - check at the control board BL and WH wires for 120VAC with oven turned to bake.
Check the wire harness from the clock to the ignitor.
Here are the breakdown diagrams and Replacement parts for Frigidaire FGS365ECD Frigidaire/range | AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-09-2012, 01:32 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
Hi Simon,
Thanks for your quick response. Im getting 120vac from the board to both the broiler valve and the oven valve. When you plug the wire (120vac) into the broiler valve and test it while connected it reads 3.6 vac. On the oven valve testing the same way it comes back at 120vac. Should i be getting the same 3.6 vac on the oven valve and not 120vac? it seems there is no power getting to oven igniter after oven gas valve. If the oven gas valve is bad can i replace just that or do i have to get the whole broiler and oven valves together? Thanks for your time and help.
  #4 (permalink)
Old 08-09-2012, 07:09 PM
Expert
Default
Hi.
Have you checked the continuity of the bake gas valve?
If the valve tests OK trace the wires and check the ignitor connector. Do you have 120VAC to the ignitor's disconnect plug?
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Double Oven Upper oven not working scri8e Oven Repair (including Ranges and Cooktops) 18 12-30-2012 04:50 PM
Whirlpool range control panel/oven not working but burners are working tacoman Oven Repair (including Ranges and Cooktops) 0 05-08-2012 09:59 AM
ge oven not working. Oven door lock problem? Deano1 Oven Repair (including Ranges and Cooktops) 6 11-10-2008 01:02 PM
Oven not working-Stovetop working Jame Oven Repair (including Ranges and Cooktops) 8 10-08-2008 09:08 AM
Whirlpool Double Wall Oven - Top Oven Not Working bigguy Oven Repair (including Ranges and Cooktops) 6 09-18-2008 09:03 AM
