| » Jenn-air oven/broiler no longer working - have details! |
Model Number: SVD8310S Brand: Jenn-Air Age: More than 10 years
Have a Jenn-air SVD8310S, stovetop is gas and the oven is electric. Last week the oven/broiler stopped working and the convection fan no longer turns on. The knobs "click" when putting it on bake, but the bake light does not turn on, nor does the clean light.
I tested the outlet with a multimeter which was fine, tested for continuity on both the bottom and top heating elements and they both checked out. Also tested for continuity on the high limit thermostat which also checked out. Here are some pictures of other voltages checked. Back panel taken off, voltages from the outlet all look great. This is the panel underneath the bake/clean/convect/etc knob. The yellow, orange, and purple wires go to the bake/broil elements and all wires (except brown which is the lock which was not engaged) read 120v when one of the multimeter nodes is grounded. However, if I try to test yellow and orange in the same manner as testing the outlet I get 0 volts??? Why is this? Shouldn't it be 240? Or should I be getting 240 out of each wire? Also, the Blue wire only puts out 97 volts, but I believe that is the clean function. Another shot of the back with the heating elements circled. Again, each individual wire reads 120v. Anyone know what could be wrong? I'm seriously at a loss as to where to go from here. Should I be getting 240v on the heating elements? Ads By Google Related Models |
| Display Modes | |
| Wall oven: Broiler and oven no longer hot enough | ccornell | Oven Repair (including Ranges and Cooktops) | 0 | 06-13-2010 07:06 AM |
| Jenn-Air Oven and Broiler Elements Not Working | DavidRG | Oven Repair (including Ranges and Cooktops) | 4 | 04-16-2010 09:54 PM |
| Follow up details on Kitchen Aid oven not heating | Rhonda Baker | Oven Repair (including Ranges and Cooktops) | 0 | 12-07-2009 09:07 AM |
| Jenn Air Oven no longer works(No code) | donna o | Oven Repair (including Ranges and Cooktops) | 3 | 11-28-2008 04:54 PM |
| Jenn-Air oven/broiler/convection oven | cgvp55 | Oven Repair (including Ranges and Cooktops) | 0 | 09-26-2008 10:07 PM |
