Discuss
Jenn-air oven/broiler no longer working - have details!
 in
Have a Jenn-air SVD8310S, stovetop is gas and the oven is electric. Last week the oven/broiler stopped working and the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-air oven/broiler no longer working - have details!
  #1 (permalink)
Old 08-07-2012, 05:41 PM
Junior Member
Synon is on a distinguished road
Default Jenn-air oven/broiler no longer working - have details!
Model Number: SVD8310S   Brand: Jenn-Air   Age: More than 10 years
Have a Jenn-air SVD8310S, stovetop is gas and the oven is electric. Last week the oven/broiler stopped working and the convection fan no longer turns on. The knobs "click" when putting it on bake, but the bake light does not turn on, nor does the clean light.
I tested the outlet with a multimeter which was fine, tested for continuity on both the bottom and top heating elements and they both checked out. Also tested for continuity on the high limit thermostat which also checked out. Here are some pictures of other voltages checked.
Back panel taken off, voltages from the outlet all look great.
This is the panel underneath the bake/clean/convect/etc knob. The yellow, orange, and purple wires go to the bake/broil elements and all wires (except brown which is the lock which was not engaged) read 120v when one of the multimeter nodes is grounded. However, if I try to test yellow and orange in the same manner as testing the outlet I get 0 volts??? Why is this? Shouldn't it be 240? Or should I be getting 240 out of each wire? Also, the Blue wire only puts out 97 volts, but I believe that is the clean function.
Another shot of the back with the heating elements circled. Again, each individual wire reads 120v.
Anyone know what could be wrong? I'm seriously at a loss as to where to go from here. Should I be getting 240v on the heating elements?
Ads By Google
Related Models
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
  #2 (permalink)
Old 08-08-2012, 04:15 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Jenn-Air SVD8310S RANGE-S/C S/I GAS & ELEC DUEL FUEL | AppliancePartsPros.com
Here is a service manual
Download SVD48600.pdf
Wiring diagram is page 4-13 and 4-14.
Why is this?
The oven thermostat must be turned on for you to see voltage here.
Using Neutral can be confusing when working on a 240 volt circuit as you cannot tell what side of the line you are actually reading. Also you will never get 240 when using Neutral as a reference.
I am not sure how you were reading the Yellow and Orange which look like they are the 2 sides of the bake element.
If you were using Neutral then if the thermostat is on you should see 120 on both sides re: BA to L2 thermostat contacts closed so L2 is connected to them.
If you where measuring Yellow to Orange then you probably would not see any voltage because if you did the element would heat up as long as it was OK. The element is not connected to Neutral and runs off of L1 to L2 voltage.
As a for instance lets say that the BA to L2 thermostat contacts are OK and you use Neutral for one meter lead connection (reference).
You will see 120 volts at the Yellow on the bake element. You will also see it at the Orange on the bake element since the element is not dropping any voltage as there is no circuit path. So it is the same voltage and if you measure across the element (Yellow to Orange) you see 0 volts.
Now lets assume that the timer relays are OK and you are getting L1 voltage at C (in triangle) BL circuit point. If you do the same measurement using Neutral you will see 120 volts at both Orange and Yellow but here is the kicker.
You are seeing L2 voltage on the Yellow and L1 voltage on the Orange so if you measure Orange to Yellow you will see 240 (element will get hot).
I hope I explained the above OK and did not just confuse you.
FYI: Just in case you do not know.
Your house supply is actually two 120 volt supplies with a common Neutral.
The two supplies are 180 degrees out of phase so when one is at positive 120 volts, the other is at negative 120 volts and that is how you get the 240 volts required to run the elements.
That your clean light does not come on in any mode seems to indicate that you are not getting voltage (L1) at BL.
Section 3 shows what looks like two hi-limit thermostats (Items 3 and 7)
They say 3 is a high limit but do not list 7. I could not find a second one in the wiring diagram so am not sure what it is doing. Usually it is controlling the blower motor but I could not confirm this perhaps I am just looking in the wrong area.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven: Broiler and oven no longer hot enough ccornell Oven Repair (including Ranges and Cooktops) 0 06-13-2010 07:06 AM
Jenn-Air Oven and Broiler Elements Not Working DavidRG Oven Repair (including Ranges and Cooktops) 4 04-16-2010 09:54 PM
Follow up details on Kitchen Aid oven not heating Rhonda Baker Oven Repair (including Ranges and Cooktops) 0 12-07-2009 09:07 AM
Jenn Air Oven no longer works(No code) donna o Oven Repair (including Ranges and Cooktops) 3 11-28-2008 04:54 PM
Jenn-Air oven/broiler/convection oven cgvp55 Oven Repair (including Ranges and Cooktops) 0 09-26-2008 10:07 PM
