| » oven element out |
Model Number: kenmore 790.9611 Brand: -brand- Age: Less than 1 year
My broiler element was sparking and emmitting a odor a couple off weeks ago. Now it has gone out along with the top burners and lights on control panel. In other words , nothing works.
Is it worth saving? Can I do it myself Kenmore Model 790.9611 Thanks Ads By Google Related Models |
Hi.
Please provide the complete model number of the unit. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Most likely there is the short in the broil element which caused the breaker to open. Reset the circuit breaker and check the surface elements and clock. If it's OK - turn the power off, pull out the broil element and check with a multimeter if there is 240VAC to the element when the clock is set for broil. If there is 240VAC - replace the element Part number: 316200600 Thank you. Simon.
__________________
Quote:
NO the burners or lights work now. |
Have you reset the breakers? Is there a 240VAC to the range?
Simon.
__________________
| Display Modes | |
| oven element/broiler element not working stove top is | MD110772 | Oven Repair (including Ranges and Cooktops) | 3 | 07-05-2011 01:23 AM |
| Oven element and broiler element won't work | mikusm | Oven Repair (including Ranges and Cooktops) | 0 | 10-10-2010 09:48 PM |
| My oven element broke and now there appears to be no power to any part of the oven | Terry37 | Oven Repair (including Ranges and Cooktops) | 1 | 06-18-2010 02:39 AM |
| Viking oven - how do I replace the bottom oven element | blueyezn | Oven Repair (including Ranges and Cooktops) | 1 | 11-25-2008 12:11 PM |
| Element won't heat up (20ohms on element and 120volts to the element)? | puddlejumper123 | Oven Repair (including Ranges and Cooktops) | 0 | 04-22-2008 07:49 PM |
