Original problem was oven locked up after self clean. I replaced oven shutdown fuse, motor latch, and control panel. Now the oven does come on and the buttons make a sound when pressed but there is no lit up display. any suggestions?
Groups: APP Team
Hi.
Make sure that all connections are good and correct.
If that the case - replace the control board again.
Thank you. Post the results.
Simon.
