Discuss
thermador downdraft vent
 in
Snorkel hangs, then drops when it goes about 1/2 way down. I can put pressure on the vent when it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » thermador downdraft vent
  #1 (permalink)
Old 07-31-2012, 05:35 PM
Junior Member
Steve Y is on a distinguished road
Default thermador downdraft vent
Model Number: cvs30r   Brand: Thermador   Age: 5 - 10 years
Snorkel hangs, then drops when it goes about 1/2 way down. I can put pressure on the vent when it retracts and it works correctly. On its own, it hangs then drops.
After removing lower access panel and blower for inspection, now the unit still hangs when going down but also continues to go up and down. It does not stop when fully up or down. Any idea what is going on? Your help is appreciated!
Ads By Google
Related Models
Thermador CVS30RB
Thermador CVS30RS
Thermador CVS30RW
Thermador CVS36RB
Thermador CVS36RS
Thermador CVS36RW
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
Crosley CW20P4H Washer - Top Loading
Crosley CW20P4W Washer - Top Loading
Crosley CW20P5A Washer - Top Loading
Crosley CW20P5AC Washer - Top Loading
Crosley CW20P5H Washer - Top Loading
Crosley CW20P5HC Washer - Top Loading
Crosley CW20P5W Washer - Top Loading
Crosley CW20P5WC Washer - Top Loading
Crosley CW20P6 Washer - Top Loading
Crosley CW20P6A Washer - Top Loading
Crosley CW20P6AC Washer - Top Loading
Crosley CW20P6H Washer - Top Loading
Crosley CW20P6HC Washer - Top Loading
Crosley CW20P6W Washer - Top Loading
Crosley CW20P6WC Washer - Top Loading
Crosley CW20P8 Washer - Top Loading
Crosley CW20P8A Washer - Top Loading
Crosley CW20P8AC Washer - Top Loading
Crosley CW20P8AS Washer - Top Loading
Crosley CW20P8ASC Washer - Top Loading
Crosley CW20P8D Washer - Top Loading
Crosley CW20P8DS Washer - Top Loading
Crosley CW20P8DSC Washer - Top Loading
Crosley CW20P8H Washer - Top Loading
Crosley CW20P8HS Washer - Top Loading
Crosley CW20P8HSC Washer - Top Loading
Crosley CW20P8W Washer - Top Loading
Crosley CW20P8WC Washer - Top Loading
Crosley CW20P8WS Washer - Top Loading
Crosley CW20P8WSC Washer - Top Loading
Crosley CW20T5A Washer - Top Loading
Crosley CW20T5W Washer - Top Loading
Crosley CW20T5WC Washer - Top Loading
Crosley CW20T6A Washer - Top Loading
Crosley CW20T6AC Washer - Top Loading
Crosley CW20T6W Washer - Top Loading
Crosley CW20T6WC Washer - Top Loading
Crosley CW20T7A Washer - Top Loading
Crosley CW20T7V Washer - Top Loading
Crosley CW20T7W Washer - Top Loading
Crosley CW20T8A Washer - Top Loading
Crosley CW20T8AC Washer - Top Loading
Crosley CW20T8V Washer - Top Loading
Crosley CW20T8VC Washer - Top Loading
Crosley CW20T8W Washer - Top Loading
Crosley CW20T8WC Washer - Top Loading
Crosley CW22B5M Washer - Top Loading
Crosley CW22B5V Washer - Top Loading
Crosley CW22B6M Washer - Top Loading
Crosley CW22B6V Washer - Top Loading
Crosley CW22B7M Washer - Top Loading
Crosley CW22B7V Washer - Top Loading
Crosley CW22B8M Washer - Top Loading
Crosley CW22B8V Washer - Top Loading
Amana CW2303 Washer - Top Loading
Amana CW2303G Washer - Top Loading
Amana CW2303L Washer - Top Loading
Amana CW2303W Washer - Top Loading
Amana CW2502L Washer - Top Loading
Amana CW2502W Washer - Top Loading
Crosley CW25P6A Washer - Top Loading
Crosley CW25P6H Washer - Top Loading
Crosley CW25P6W Washer - Top Loading
Crosley CW26P6KA Washer - Top Loading
Crosley CW26P6KH Washer - Top Loading
Crosley CW26P6KW Washer - Top Loading
Amana CW3303L Washer - Top Loading
Amana CW3303W Washer - Top Loading
  #2 (permalink)
Old 08-01-2012, 06:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Steve,
The problem can be a bad/misaligned limit switches and/or a bad drive assembly. You can find the instructions in the attached service manual.
Here are the breakdown diagrams and Replacement parts for Thermador CVS30RS COOK "N" VENT DOWNDRAFT SYSTEM | AppliancePartsPros.com
File Type: pdf ServiceManual_rh30019e_CVS30-36-45.pdf (494.8 KB, 30 views)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-01-2012, 07:40 PM
Junior Member
Default Cvs30rs
Quote:
Originally Posted by Gene View Post
Hi Steve,
Thank you Gene. After disassembly, the problem turned out to be a lose screw on the motor arm connecting it to the motor shaft. It caused the snorkel to drop and was lose enough to miss the limit switches. After tightening the screw, all is well.
  #4 (permalink)
Old 08-02-2012, 11:26 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Steve. I'm glad you were able to fix it and the problem was that simple.
Thank you for the feedback.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool downdraft vent sorton1111 Oven Repair (including Ranges and Cooktops) 0 07-18-2012 06:07 AM
Frigidaire Downdraft Vent Goes Up & Down, Over-and-Over savialb Oven Repair (including Ranges and Cooktops) 0 12-13-2010 06:54 PM
telescoping downdraft vent teddy9plus Oven Repair (including Ranges and Cooktops) 0 08-21-2010 02:33 PM
GE Downdraft Vent Dissassembly jrtrades Oven Repair (including Ranges and Cooktops) 0 11-20-2009 02:36 PM
Telescoping Downdraft Vent David Griffith Oven Repair (including Ranges and Cooktops) 0 04-03-2009 10:04 AM
